Orc lightweight flwheel (-4kgs)
Hicas removed (-20kg)
Nismo LM GT-4 18x7.5 forged alloy lightweight wheels (-15kg)
Rays Engineering duralumin wheel nuts
Gtr bonnet (-15kg)
Stripped boot/interior(no back seats or steabelts) (-15kg)
removed driving lights (5kg)
Nismo mats (front only fwiw)
Gtr seats (-10kg)
no rear speakers (-5kg)
removed stock rear spoiler (-5kg)
= 95kgs :no:
Added,
front and rear strut bars (4kg)
turbo timer, ebc, 2 guages, alarm (5kg)
intercooler (5kg)
gtr rear spoiler (sometimes off) (10kg)
= 25kg max
1360 - 70 = 1290 :)
Notes: standard spare, jack are still in boot, not leaving home without them :P Center seatbelt is gone, along with the plugs for the side seatbelts. Side seatbelts and trims remain.
All feedback welcome!, i gotta get this dog under 1300 :no:
Edited by 2630GTS
https://www.sau.com.au/forums/topic/149105-lightweight-mods/
  • Replies 105
Is your car a r32 gtst coupe?? if so i thought they were 1320kg from factory?, i have heard that the older r32's (1989-1991) were lighter as the newer r32's have extra side intrusion beems or something along those lines which adds weight to them, also factory fitted options like sunroof,abs etc will add more weight to your car.
My old 1989 r32 gtst 4door auto with sunroof and no abs weighed 1330kg on a weight bridge with full standard interior, sounds, coilovers, 17"s, front mount, front and rear strut braces, so your car could possibly already be under 1300kg with the parts that you have removed.
sound deadening stuff... pain in the A to remove, but if you want KG's, its a good place also
plus things like batteries also. is another one
apparantly using dry ice to freeze the sound deadener then hitting it with a hammer is an easy way to remove it, i'll be testing it out soonish on my torana.
was suggested in Majanal's drift car build up thread in the drift section
and going as far as empty washer bottles, they hold a few ltrs so there is a few kg's there
Good point about the battery, ill change that when i move it to the boot.
I dont want to go overboard and empty the washer bottles, i really just want to get it under 1300kgs, with half a tank of fuel would be nice too ;)
For now wont be removing anything else except the air con and last of the rear seatbelts.
Just wondering on what people thought of the weights i came up with and weather or not i would be under 1300.
Edited by 2630GTS
Its a 93 coupe with sunroof and abs. I though stock weight was 1360 without the sunroof and abs, hmm.
Good to know a weight someone has actually got from a weighbridge tho, thanks ;)
R33 GTS25T coupes are quoted by nissan to weigh 1360kg so i highly doubt a r32 gtst will be the same weight lol, also if your driving by yourself most of the time you could remove the passengers seat as they do weigh a bit, and you could remove other things like both rear seats, parcel tray, aircon if you dont use it, glovebox, remove anything that you dont need and leave the bare essentials if you want to get serious.
im not sure what my 33 4 door weighs in at, my aim is to get it down to 1100kg, i think ill be pushing my luck but
note, its a race car
ive pulled out everything, literally, the only thing the interior will have left, is two momo seats, a set of harness's, and the dash, with nothing behind it, no air boxes, no fan unit, no plastic trims, no roof lining no nothing.
Saddly, i loose all that, but have picked up about 50-70kg of roll cage..
sound deading is easy to remove as mentioned, use dry ice, lay it about an inche thick on the area you want to remove, give it 5-10 minutes, clear the ice away, and wack it with a hammer, or just lever the side of it with a screw driver, should break up in bits, some will be harder to remove and may need more time witht he ice, but it'll eventually come away..
for anything thats left, grab a die grinder, and hit bunnings for what is effectivly a plastic scourer in a disc form, it'll get rid of what remainds quick as a flash
other stuff ive done is turf the heavy stock bonnet for a fibre glass jun copy bonnet
plexiglass side windows, 3mm thick, removed the rear door window motors, front and rear windscreens are still glass
other stuff to come is a complete reqire of the car, when i get a motec for it, so ill loose probably nearly 50kg of wire that just does not need to be there
also will be going for new fibreglass front and rear bumpers and guards..
there is a lot more i could do, but itd mean no fast glass front windows, and lots of holes carefully cut in various bits of the body, which im not so fond on the idea of..
if your really cashed up, you can get carbon fibre doors for 33 coupes, you'll pick up a good 30kg a door from those alone
and if your really keen, strip the thing to a bare shell, and dunk it in a pot of acid, to thin out the panels, the WRC cars egt this treatment, other people i know grab a belt sander and manually thin out the panels, read floor etc
Id be thinking of this one, where did u get yours from, im thinking of having the sunroof remade from plastic too.
I just made templates of the old windows from floor lino, and texta outlined them onto some plastic sheet, then cut with a saw, bandsaw works best, jig saw will cause it to break very easily
probably a wiser idea to use lexan, as its less likely to crack and break like plexiglass/perspex will
not sure on what lexan is per square meter tho
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
