OK as most of u are aware my stagea, and nearly myself too - met an untimely death at the hands of a pole.
The car is A1 from the front doors, back. Nothin rear of the front guards was touched, save for the side skirts are cracked but repairable, as well as the rear bar. Doors, trims, interior seats etc.
Anyone thats seen the car knows it gets cleaned, vacuumed and amouralled weekly, so if something pops into ur head u might want, let me know. Am happy to take pics if u want closeups of anything.
Cheers!!!
Rob
EDIT -
i have brand new shocks and coils from SK's group buy. Bilstein and whiteline, with the addition circlip grooves for adj height settings. Never quite made it to the car.
Edited by qikstagea
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/
  • Replies 98
I need the clips in the boot area.. I'll take a pic of whats broken on mine so you know what I mean lol
i had to get new ones of these too, cost me a whole $8 for one from nissan, probably easier to get them that way.
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2781945
sorry to hear wat had happened to your car though. Wats you color of your interior trim? Im lookinhg for a driver side rear door interior trim and how much? Thanks pal
BTW do you have whiteline swaybars? Will it fit 260rs? and how much?
Edited by stasis
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2782006
- AIR DEFLECTORS!!! (I've got dibs!)
- Your rear diff (complete diff inc housing, going to weld it/drop front shaft for some RWD fun)
- Handbrake pads (If in decent condition, I need new handbrake pads)
- Plastic surround on front driver door skin for the handle to open the door.
- (NOT SURE IF YOU HAVE IT) The motor in the rear hatch that closes the boot itself.
Will think of more later :)
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2782771
oh yeah i forgot the difference between S1 and S2 shocks my bad!! scratch me out on the shocks etc. then thanks.
i know its a S1 but are the tail lights S2? if so i want em as i have a cracked lens in the drivers side unit on mine.
also did you have upgraded coil packs (splitfire) or similar?? on your engine, if so i'd like dibs on them please, if they are rescuable of course that is?
Edited by oxford1327
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2782923
wol., Why won't rear shocks fit? I believe S1 and S2 shocks are the same.
oxford has the manual version and they are different. there is a fair bit of evidence that the manual versions have R33 GTR running gear hence some parts that were expected to fit do not.
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2783033
So manual S1 and S2 plus 260RS has GTR rears. Ok cool!!
There was no manual s1 (apart from the 260RS) - so just the manual S2 (ie the rs4s) and the series 1 based (upgraded a lot!) 260rs (If they had done a series 2 260rs - ie a S2 upgraded to r34 parts - I would have bought one! :) )
Ian
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2784394
i think that there is a series2 autech/260 rs for sale in QLD at motorman imports. but whether or not these "genuinely" exist or are a conversion i am not sure, maybe one of the guru's will be able to shed some more light on this?????
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2784426
i think that there is a series2 autech/260 rs for sale in QLD at motorman imports. but whether or not these "genuinely" exist or are a conversion i am not sure, maybe one of the guru's will be able to shed some more light on this?????.
in the meantime i will try and find a link to the ad for it and post it up here.
stay tuned.
cheers oxford
https://www.sau.com.au/forums/topic/149108-feeding-frenzy/#findComment-2784429
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
