Now I know that theres a large market of mods for R32's and R33's out there, but how are things on the R34 front?
I know you can make your car go as fast as you want it to depending on the size of your wallet etc.
But what kind of mods would have to be done to an R34 GTT to match/better an Evo 6 or other "quickish when stock" cars.
Im asking because availability of mods is something I need to consider when I get a skyline.
much appreciated
Execute flaming now.
Edited by Dingo
https://www.sau.com.au/forums/topic/149146-modding-a-34/
Hey,
I have just swapped over from a 180sx that has an unlimited list of aftermarket goodies available to an R34 and I was quite suprised the lack of available parts and options for the 34, sure you can get alot of parts but there isn't much variety if you know what I mean.
But on the other hand I have found they respond very well to mods.
The only let down is the turbo, but there is a sponsor on here that does a Hi-Flow version quite cheap.
As you stated it all realy depends on one's budget.
Hope this helps
Cheers
Josh
https://www.sau.com.au/forums/topic/149146-modding-a-34/#findComment-2782113
generic cooler kits, turbo kits, injectors, universal fuel pumps, coilovers, ecu upgrades, wheels, gauges, exhaust systems..... i cant really see it a problem getting any of these to suit a R34 GT-t.
If you buy Japanese, or name brand, you shouldnt have any issues with finding stuff.
Greddy (Trust)/Blitz cooler kits
bolt on Garrett turbo upgrades to suit stock manifold or a Greddy/Trust kit.
Injectors (Nismo/Sard etc)
Bosch/Walbro/Nismo fuel pumps
Tein/HKS/G4 coilovers
Power FC/Haltech/Microtech/Wolf/Autronic ecu ugrades
Wheels, anything Jap like Volk/Rays or a GTR wheel
Gauges, (Blitz/HKS/Defi/Greddy/Autometer)
Exhaust, maybe X-Force does a bolt on kit, otherwise something Japanese.
Would be as easy to mod a R34 as it would any Skyline Id say, especially if your willing to buy brand new. Obviously the second hand market wont be any where near as strong as the R32/R33 market as the R34 hasnt been around as long.
Edited by _8OO5TED_
https://www.sau.com.au/forums/topic/149146-modding-a-34/#findComment-2782849
Its already pretty big. Prices of R34s have dropped in the past year making it a more affordable for R32 nd 33 owners to upgrade to.
Lack of parts? I don't think so...there are so many online traders/sponsors importing stuff in from Japan its not funny..I struggle to resist throwing more $$ into the 34 every single day :)
https://www.sau.com.au/forums/topic/149146-modding-a-34/#findComment-2784169
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 馃槂
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
    • Correct. The ECU cannot read oil temp. (Well, I think it probably can in some situations. I did have the thought of potentially repinning the ECU when I was doing oil pressure). I am using this into the MPVI dongle, so that the MPVI dongle can read oil temperature. It is attached to a VDO gauge which is obviously calibrated to whatever curve the sender actually is using. This would be easy if I could setup a table of voltage to temperature like many sensors, but it appears I cannot do this and can only setup the transform rule which appears to be Input (voltage) x Multiplier, and add an offset. This to me means it MUST be linear. So it may be a complete waste of time wiring this into the ECU. The idea was that the MPVI3 has standalone logging. I wanted to use this instead of a laptop with serial cable (for wideband) for long datalogs. Given the wideband also has electric interference, I may never trust this either in a world where the serial wideband and the analog output wideband do not agree. Last time I did a trace I could see the two wideband traces follow each other, but one was a little leaner than the other. I plan on playing with voltage offsets and actually driving the thing to see how close they correlate. If they never correlate... then, well, maybe I'll never use either. Ideally I'd like to have the Analog wideband read ever so slightly leaner than the serial one, because the serial one is 'correct'. Tuning the car to be ever so slightly too-rich would be the aim. Not needing to have a laptop flying around in the footwell connected with cables is... an advantage. About the only one from the forced upgrade to MPVI3.
