Hey guys, as we all know with performance upgrades comes dilemmas! My mechanic will be fitting the 550cc injectors, highflow turbo, nismo fuel pump and FMIC. However my tuner is 20min drive away and need to get the car to him to fit and tune the ECU.
Will my car fire up and be “drivable” for about 20kms with the factory ECU?
Regards,
Sarkis
Hi Sarkis,
I had fuel pump, FMIC and Highflow all running on stock ECU, i'm unsure of the injectors though as i installed PFC and injectors at the same time.
What aftermarket ECU have you got?
IF you got pfc then just program your injectors by using the hand controller and then drive to the tuner.. that's what i did.
Yea might just do that.. however the tuner wants $200 to fit the injectors
Im still tossing up between PFC (cant find them under $1200) or a Haltech (recommended by my tuner) he also tunes PFC but he cant get them anymore...
Cheers
I have never changed injectors before so i wouldn't know where to start... since ill be using a Nismo pump and injectors, if i cand get my hands on a PFC i can take my time and do it all at home and then adjust the injectors so i can drive it there... ill see how i go... cant find a PFC anywhere...
Cheers
my mate just bought a pfc from this site,but man was he lucky i was up late and spottered it... he did pay 1200 tho...
good luck finding 1
i got a brand new power fc in box with hand controller and warranty for rb25det if anyone wants to buy it...i just want wot i paid for it:)
Yea but the PFC is hard to come by these days... EMS or Haltech ECU comes with slightly more options as well as no need for an AFM...
Ill be visiting a few workshops in early Jan and see what they recommend...
I have the Injectors, Fuel Pump and FMIC sorted just need to decide on turbo and ECU... hopfully will see 260+rw/kw
Have a great New Years Eve guys... Keep Safe
Regards,
Sarkis
No he didnt say 3hrs, he told be he could do it for $200 but would rather someone else to do it... he specilises in ECU installs and tune... He is no tool let me assure you... he has some of the most powerful cars coming off his dyno inc BU5TER
http://www.justenginemanagement.com/buster.html
He knows his work very well and would highly recommend J.E.M (Adam)
Cheers
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
