Hey guys, i know the ECU debate has been discussed over and over and an ECU will only be as good as the tuner, however i have not found any info on the EMS 8860 in regards to the R33 RB25DET.
Here are my options with some prices that my tuner has advised (order of preference)
Haltech E11v2 - $2800 (supplied, fitted & tuned)
EMS 8860 - $2200 (supplied, fitted & tuned)
EMS Stinger 4 - $1800 (supplied, fitted & tuned)
Apexi PFC - $1700 + $350 Z32 AFM = $2050 (supplied, fitted & tuned)
Any info or comments will be appreciated
Regards,
Sarkis
Edited by QRI05E
https://www.sau.com.au/forums/topic/149199-ems-8860-stinger-4-ecu-for-r33-gtst/
Can you find me a new PFC with h/c for $1000? and Z32 for $200?
the quote i got:
PFC: $1200 (new)
Tune: $500
AFM: $350 (new)
One workshop quoted me $1000 but ex h/c
If you can please let me know and ill buy it today...
Any feedback on the EMS? they seem to be good
Cheers
Edited by QRI05E
Nengun dont sell the PFC for the R33 GTSt anymore... they have been discontinued
The Wolf V500 retails for $1,895.00 excluding harnes and tune
Wouldn't the Haltech be a better choice at that price?
ok sorry those prices i qouted were second hand here. theres nothing at all wrong with second hand power fcs and same with the z32 afm. but with the afm check ebay you can get new ones on there pretty cheap i think.
Yea Paul but thats too much stuffing around for me... i'd prefer to get the whole lot installed and tuned professionally... $1800 for an EMS stinger fully fitted and tuned sounds like the way to go...
Cheers
i know what i would do if it was my money
how many people can tune the EMS?
what features does it have?
map?
afm?
closed loop feedback?
what is the base map like?
does it have any form of hand control / user input/output device or is it software only?
is it a sequential ignition driver or batch fire?
wire in or plug n play?
I think that is cheap for supplied fitted and tuned. EMS are about the only computers I have heard more bad stories than good about tho.
Also, if you are going the Stinger option, its not really the best way to go, as it only has 4 injector drivers. I assume they will set it up the same way they setup Microtech LT8's for 6cyls.
It can be done, but its not the ECU meant for that application.
If you are comparing those prices, a microtech LT8 installed and tuned would be even cheaper.
Either way, I'd go for an ECU that is meant to run 6cyls.
What about the EMS 8860? it has 8 ignition drivers.... but for $2200... would rather spend bit more and get the Haltech... Buy if i can find a good buy for a PFC for GTST i would grab it...
Edited by QRI05E
u want to spend even more than 2k? geebus, u got money to burn in your pockets? contact some of the 2nd traders on this forum to see if they can source you an rb25 pfc, they are usually on yahoo auctions
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
    • Discover the best Halal food near you with Maharajaonline.com.au. Our delicious selection of Halal dishes will satisfy your cravings and make you feel like royalty. Try us today and experience the difference!   halal food near me
