Ive been told by an accident investigation officer who was on my case when i crashed my Pulsar that insurance companies cannot look up a persons driving record. They cant as such "chase it up" when you have an accident.
The only charges they know about ARE:
The ones you tell them about and..
The ones that are as a direct result of a claim you have made eg: if you have an accident where its your fault, you are charged, the police then inform insurance of this because it determines who is at fault.
Its alot to do with privacy law and so I am told.
If anyone knows otherwise, correct me. I know there is someone on this board who works for insurance, they might know.
Red17
I am under 25 and had a clean record up until early this year when I crashed my 180 on a cruise. The RAC have been great - my preimium only went up $100 and I lost 5% of my full no claim bonus. When the 180 was written off - not my fault - they paid me out straight away no questions. They know all about my speeding fines and everything. RAC even insured my 180 from the time it was the wharf until it was complied and assessed for a full insurance value. I told them the car was not aus standard and they said it was fine so long as I provided the details of registration and compliance when it was done. Maybe you should give the RAC a call and see what they can do for you?
so if i had an accident about 6 months ago and it was my fault ... the cops charged me with something like .. not keeping control of my car and fined me 200 bucks ... i made a claim with an insurance company and all went well ... got it fixed ...will another insurance company know?? that i had that accident and made that claim??
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
