Hi People's
Just Wondering if you could give me some Comments, Advice, Guidance etc.. n Opinions about this Matter.
Went to Drags for the 1st time.. n i wasn't really sure what to expect. So just want to know if you reckon this is a Reasonable Time that i got or if i could go faster...
Car: R33 GTS-T Series 2
My Mods are 3" Turbo Back, Hybrid GT FMIC, 10 Psi Boost, 9 Puck Clutch, HKS Pod, Cusco Coilovers. Got 17" Street Tyres.. 245/45'z they Nexen N3000 Tyres. I Removed the Backseat n Spare Tyre.. n dropped the Back tyre Pressure to 28 Psi.
Best i got on the night was
60' 2.302 sec
330' 6.032
660' 9.087
660' Speed 131.02 kph
1000' 11.696
Reaction Time: 0.557
Terminal Speed: 163.83 kph
Elapsed Time: 13.921
Thankx
Edited by Black_CSR
https://www.sau.com.au/forums/topic/149203-14-mile-runs/
  • 3 weeks later...
Hi Guys Went Down Again.. Tried Several Things... n Suprisingly my 1st Run was my Quickest time of the Lot.. had about 6 Runs. Last Run (Slowest) where i dropped the Tyre Pressure to 17 Psi.. N Where my 1st run (Fastest) was about 21-22 Psi.
LAST RUN
60' 2.475 sec
330' 6.622 sec
660' 9.893 sec
660' Speed 124.87 kph
1000' 12.556 sec
Reaction Time: 0.586
Terminal Speed: 162.36 kph
Elapsed Time: 14.816sec
1ST RUN
60' 2.328 sec
330' 6.021 sec
660' 9.053 sec
660' Speed 131.79 kph
1000' 11.614 sec
Reaction Time: 0.600
Terminal Speed: 168.20 kph
Elapsed Time: 13.790sec
Managed to get my 60" to 2.257sec but got 13.960 ET
So how do u get a better 60" Time? n What Revs do u guys Launch it on?
What if u get heaps of wheel spin during take.. off, do guys short shift 1st etc..?? Tried different things.. not sure wat 2 do next time hehe :laugh: TA
-SeSaR
Edited by Black_CSR
https://www.sau.com.au/forums/topic/149203-14-mile-runs/#findComment-2832571
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
