89 model r32 gtst with rego till 02/10/07 full black widow immobiliser and alarm
105,000km
serviced every 3000km
only ever use 98ron fuel with octane booster and injector cleaner used about every 10th fill up
3.5" turbo back kakimoto exhaust
450x300x80 fmic with 2.5" piping
600hp walbro pump
high flowed ballbearing r32 turbo
high flow hks panel filter
r34 gtt wing
type m front bar
17" enkei rims 8" at front from memory and 9.5" at back with 255 dunlop 9000 rubber on rear and 235 on front also will have standard rims and rubber supplied
new clutch installed on 85,000km
new fuel filters intank and out of tank installed on new fuel pump installation
very tidy car, a few small dings over the body and front kit is cracked, interior is immaculate car has been very well taken care of, but i am no longer alowed to drive due to p plate restrictions and me getting in trouble.
pics will be up soon
i live close to eastern creek in western sydney, if you have any interest please pm me and i can give you more info
i am after $9000 which i think is very reasonable for a very well looked after r32 gtst, it has been my baby for 2 years, first owner in australia, and this is also my 3rd r32post-5992-1167476742.jpg
Edited by nemz
https://www.sau.com.au/forums/topic/149218-black-r32-gtst-5-sp-turbo/
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
