no BOV = anyproblems??
well as its a stock one.....it looks nothing like an aftermarket one. not sure about 32's but on a 33 they're this ugly small grey roundish thing thats attatched to one of the intake pipes. follow ur intake pipes and there should be something odd bolted onto it:D as u say your hearing a whistling sound after lettin go of the gas its best bet that thats the sound of ur bov...doesnt matter if its auto too.....my friend had a 32 auto.
Guest RaBZ3174
oh ok thanks alot man..yea i think thats y i didnt think there was a BOV cauz it didnt look like an aftermarket one and didnt generate as much noise as my freinds r33..although i still ran him off the rd.. im gonna go look for the grey roundish ugly thing :P thanks alot mr fanny!!!
if theres no affect on the motor through a BOV why then do most factory turbo cars have BOV's stock?
AFAIK thier there to improve response by decreasing the chance of backpressure slowing the compressor when the throttle is slammed shut.
or boost spikes?
I put my aftermarket BOV on so i could have something quieter than the stock one. My old stock one used to make a HEAP of noise (probly because of my air filter pod) and was really sensitive.
Whenever i came on boost with the stock bov i couldnt hear the motor underneath the sound of air rushing. Aftermarket BOV has reduced the noise by over 50 percent id say, now all i hear is the howl of 6 lovely RB cylinders. Not sure if all 32 bovs were as bad as my one or if mine had a problem. But its better by far now.
Red17
kwazza: i think u've missunderstood. i dont think anyone here said that having no bov wont do anything to ur engine. just reinforcing to Rabz that his car and all gts-t's have stock blow off valves...be it auto or manual. Predator and i were just saying from opinion that an aftermarket one's over the stock one wont give u any great performance gains.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
