since they are 2 licences (motorbike and car licence), dont u loose ur motorbike licence and get to use your car licence then?
Your car/motorbike & boat liciences are all tied together...
I was breath tested this morning at caloundra at the boat ramp before going wave jumping on the jet ski... First time this has ever happened, but the water police did a check on my licience number to see that I have done the latest jet ski licience update and that I was on an open licience... I blew 0.0 tho as i didnt have a heavy night last night... But its the same rules as the road when on water...
The only licience I have that cannot be taken is my 14t forklift ticket... :P
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2785207
lol forklifts on road is not good. a friend tried it. first corner and it flipped. then again he was doing 60k's down the markets at the time and they are rear wheel steer :D
he doesnt work for the company anymore :P
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2786786
lol bl to the motorcycle license.....hope you learned you lesson
:P or atleast plan to revenge it somehow with some cheekyness
neways never mind man, everyday is closer to get your license again
lol yeah forklift pimping for the win....but taking it for a spin on the nice tar out there is a baaaaaaddd idea :rofl:....funny
but oh so bad
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2791752
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
