since they are 2 licences (motorbike and car licence), dont u loose ur motorbike licence and get to use your car licence then?
Your car/motorbike & boat liciences are all tied together...
I was breath tested this morning at caloundra at the boat ramp before going wave jumping on the jet ski... First time this has ever happened, but the water police did a check on my licience number to see that I have done the latest jet ski licience update and that I was on an open licience... I blew 0.0 tho as i didnt have a heavy night last night... But its the same rules as the road when on water...
The only licience I have that cannot be taken is my 14t forklift ticket... :P
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2785207
lol forklifts on road is not good. a friend tried it. first corner and it flipped. then again he was doing 60k's down the markets at the time and they are rear wheel steer :D
he doesnt work for the company anymore :P
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2786786
lol bl to the motorcycle license.....hope you learned you lesson
:P or atleast plan to revenge it somehow with some cheekyness
neways never mind man, everyday is closer to get your license again
lol yeah forklift pimping for the win....but taking it for a spin on the nice tar out there is a baaaaaaddd idea :rofl:....funny
but oh so bad
https://www.sau.com.au/forums/topic/149259-fugg-it/#findComment-2791752
    • I think the catch can design is pretty flawed. Evident in the fact that the V2 one moved to a larger top mounted filter which alone would have helped with overflow and reduce restrictions compared with the side filter. I also imagine there was a major improvement to the baffling design. It is worth mentioning that this catch can with the RB20 was never as much of an issue and the high kms RB25 is likely a part of the problem. I have gotten quotes for both a new "Vibrant Gen 3" catch can and to modify this existing ones but that may have to wait until after the track day. I hope the sump/head breathers/drains and cam splash plates will be enough
    • Yep, both. The ratio is 1.8 instead of OEM being 1.7. The rocker bodies are modified with a larger bolt hole and re-threaded with 10mm holes instead of the 8mm YT has stock. Finding out they don't actually fit the stock castings cause a lot of un-impressment by the person in the USA who tapped the new holes for the 'upgraded' YT product. He was very unhappy with them given their previous design did not require 'clearancing'
    • That too, but I think this is why she's put the work into the cam cover baffles. I mean, a catch can should only need to be a catch can, not an oil air separator also. Not to say that putting the effort into having it do a better job of oil-air sep is a waste of time, but doing the sep earlier is always going to make life better. And that should happen now anyway.
    • I think both. Higher ratio and more stout. I think at least part of his lift increase came from the rocker.
    • At 30cm long, you only need 80lbs... Which isn't hard to put that much weight in. Just start to stand on it, but not full force. Even a light weight size 6 lady can do it. If I stood on, I'd get them to about 190ft-lb... And all Id need to do is... Stand...
