  • Replies 45
Take it to someone near uni like SST and ask them to run it up on the dyno to see if the output is normal for a stockie. If not I'm sure it may only be something minor that they can fix.
The rest of us will only be guessing
https://www.sau.com.au/forums/topic/14927-r34-performancee/#findComment-303601
Originally posted by GTS-t VSPEC
+1 does seem to be low, should be making it to +3 at least. Take it to a tuning shop and let them take it for a drive, they'll tell you if anything is wrong:D
For info: the +1 reading on a 34GTT factory boost gauge is equivalent to 14.2 PSi. So if Erik's car is stock the standard boost gauge should go to approx halfway between 0 and +1. Mine went closer to the 3/4 mark BEFORE any bleed valve was fitted, which "indicated" around 10psi, however stock boost is .55 bar / 7.9 psi.
After dyno testing I have discovered my factory boost gauge is out by approx 2psi - at least I know now.
Will look for pic of gauge to illustr8
Useless fact #4: +1 is Kg/cm2 which is 0.98 of 1 bar thus 14.2 psi...
https://www.sau.com.au/forums/topic/14927-r34-performancee/#findComment-304301
Wow guys that's for the replies, I can't really reply due to Uni works Shit like hell.
nismoR34 my one has stock standard boost gauge, the max i can push only halfway and seems OMG it's so hell slow.
Where can i do dyno testing? I think I want to try it.
U guys all wanna take a look?
Caminperth , unfortunately I can't let anyone drive my car, if they just want to rape my turbo engine :(
adam32, my seatbelts are fine.
https://www.sau.com.au/forums/topic/14927-r34-performancee/#findComment-304397
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
