  • Replies 45
Erik, if you are going to modify stuff [ie airfilter] do the dyno FIRST!
Its better to test as-is.
GTS-t VSPEC: no probs mate. So what measurment is used for the 33? I never had a close look when testing them - too busy keeping it str8 :) [with dealer sitting next to me].
Useless fact #101: The "0" reading on the 34 guage [see pic above] is neither boost nor vacuum - which sits at halfway point between -700 mmhg [vacuum] and +1 kg/cm2 [boost].
Erik you must be hitting the 1/2 mark between 0 and +1, one post you said 3/4 another post u said 1/2 - so which is it?
Just trying to work out if your boost is in the normal range or not!
Originally posted by eriktufa
sorry nismo 1/2 from 0 to 1, 3/4 the whole boost gauge, i think i'm getting a new one. Dang , i put air filter already today with nice sound, cheap one 35 bucks hehee it's nice sound
ok, that is definately in the normal range for a stock 34! Mine used to be like that too :)
Maybe you should organise a dyno run dude, get them to check your CAS [crank angle sensor] timing and listen for detonation while your there. If it doesnt pull around 150+ kilowatts then there may be something wrong. Mine with some minor mods recorded 182kw.
Also what type of fuel do you use? If you put normal unleaded [89-93 ron] or even so-called 'premium' unleaded [93-95 ron] in your car this could cause problems like timing retardation or detonation. You definately need to get the car looked at if its not running like it should ~ which is ~ fast!
I only use BP Ultimate - 98+ octane.
expensive? In Vic its usually cheaper for me than Optimax.
I have heard its made here though so you guys would pay more in transport costs - but at least you can get Ultimate / 98 octane fuel, not everyone can get it Aust wide.
Prices are normally:
Ultimate - maximum of 6.5cpl dearer than unleaded
Optimax - maximum of 8.5cpl dearer than unleaded
Both s/stations are usually the same advertised price so Ultimate is normally around 2cpl cheaper!
Just my 2c worth :P
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
