Nissan Skyline R32 M-spec 9/1992
140,000 genuine klms I am original owner last 5 years, 73500klms when I first got the car in 2002
Rego till 26th october 2007
Metallic black
Manual
Mods include the following:
HKS pod filter
Turbo timer
GFB boost controller
5-puk clutch (3 month's old with machined flywheel)
Haltech E6K ECU with 3x Haltech double ended coils and an M+W igniter (has a launch control button currently deactivated)
GTR Fuel pump
6x GTR injectors (not fitted but will be supplied with sale)
Trust cat-back system with hi-flow cat also installed
lowered onto King springs
Slotted DBA front rotors with Bendix ultimate pads, GTR drilled on rear (stops very well!)
Quicktrak alarm installed featuring constant vehicle monitoring, panic button, keyless entry and service (NRMA) call out funtion
JVC CD player
This car has been serviced every 5,000klms and meticulously maintained, the climate control aircon is icy cold, there is no broken dash vents or ripped seats, carpet etc. The timing belt was changed at 95,000klms. I have all original import documentation to prove klms, ownership etc and reciepts for modifications. Few minor park dents + scratches, but that's it guys it is a clean honest car.
All you need is a front mount and larger turbo and your in business, unfotunately due to me buying a Stagea for an expanding family this is when we have to part company.
SOLD
Edited by wagonwheels
https://www.sau.com.au/forums/topic/149276-sold/
  • 3 weeks later...
  • 4 weeks later...
Guest
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
    • Try using Penrite 80W140, has Limslip predosed into it
