Almost completed my engine/gearbox conversion on my cefiro. I only put power steering fluid in today and found that the power steering isn't working.
The power steering and hicas was working before the conversion started. Since then I have replaced the rear subframe with a non-hicas item, removed the rear lines, the hicas solenoid, and looped the hicas supply straight into the reservoir.
I've read all the stuff I can find on power steering/hicas issues on SAU.com and NS.com
Here is a list of things that I have considered and what I've tried.
The power steering pump on the new engine is rooted?
I disconnected the lines off the pump and turned the engine on, fluid came pissing out the fittings so I'm assuming that the pump is working. I can't try my old pump (which I know works) as I don't have it anymore.
Issues with the power steering solenoid
Battery is fully charged and alternator is working, so it's not a voltage (or lack of) issue. I have a spare R32 rack (non-hicas model), and can see the solenoid is mounted on the rack next to the connection block and has 2 wires coming out of it. I can't find a solenoid like this on the cefiro rack. Do cefiros have a power steer solenoid on the rack?
I have considered swapping the R32 rack and lines in, but the R32 lines don't appear to have a pressure sensor (apparently it's an idle up for the power steer pump?).
Speed Sensor
My speedometer is working, but that is cable operated. Is there a way to test my speed sensor?
Hicas Computer
I don't know where the hicas computer is located on the cefiro. The hicas warning light was on when I didn't have fluid in the reservoir, but it has turned off since I filled it with fluid.
I jacked the front of the car up, and turned the steering wheel left to right with the engine on, to try bleed the air out, but it didn't have any effect.
I could try the R32 rack, but I don't know if it does work (it came out of my half cut) and it doesn't have that pressure switch on the supply line.
I'm assuming since the steering was working before the conversion that the problem is either electrical related (speed sensor or hicas computer?) or that the p/s pump isn't making enough pressure.
Is there a better way of testing the pump, besides disconnecting the lines to see if fluid comes out?
Would appreciate any input related to this problem,
thanks, Luke
Edited by daisu
https://www.sau.com.au/forums/topic/149334-powersteering-not-working/
I reckon it could be hicas computer not plugged in. It goes heavy when it's not plugged in.
Have you checked under the parcel shelf for the computer? That's where I'm guessing it would be as that's where it is on R32s. On S13s it's supposedly in the rear left arm rest, but you have a 4dr so I'd doubt it would be in there
May sound like a stupid question but did you loop the rear outlet of the pump into the front inlet of the resevoir?
There are no spare plugs or computer under my parcel shelf. There is a computer behind the drivers kick panel but I'm assuming this is the auto computer, it is plugged in anyway.
I didn't think the orientation of the return lines on the reservoir would make a difference, as it is just a collector.
Can someone tell me what the hicas computer looks like, how big it is, it has 2 connectors right? How many pins are in the connectors? Is there any obvious writing on the computer?
Thanks
Well I'm just thinking if you took off the rear return line, this is the return from the front rack, so if this isn't working, you wouldn't have power steering. Just a stab in the dark
The Hicas computer is around 180x150x40mm. One of the plugs has 2x4pins and I think the other has 2x6pins could be 2x5 though, cant remember...
Dont remember anything distinctive on the computer, just plain looking like the ECU.
I removed all the hicas related lines and left the front power steering completely alone. Then I had 1 spare outlet from the pump, and 1 spare inlet to the reservoir which I connected together.
Hopefully I'll find the hicas computer tomorrow.
Edited by daisu
I didn't end up finding the computer, so I replaced the p/s pump. It was a real pain in the arse to fit the replacement on, especially when everything is covered in p/s fluid and the sun is beating down on you in the arvo. Turns out it was the pump and not the computer or the rack (thank god for that).
:P
    • Just don’t be silly enough to think it’ll never happen either
    • I take it that you bought the centre to suit the GTR axles? As in there was a plan, not just somehow lucky that it worked? It all looks excellent, by the way.
    • New engine block time. Up to you whether you want to keep going down this road with this project. Unfortunately a lot of these cars are like this. The road to getting these cars into decent shape is long and not fun for reasons that you're discovering.
    • Essay time. First things first, an RB running stock turbo and boost levels shouldn't get so bad as to stall from reversion if the recirc valve has been deleted. Should get a little fluffy and annoying, but in my experience, not so bad as to stall. Of course, every car is a bit different, so it remains possible that stalling will happen. So, running with no recirc valve is somewhat of an option, for otherwise stock stuff. Atmo BOVs cause all sorts of shit, even on an otherwise stock setup. Only gets worse the higher the boost and the bigger the turbo. At that point you really need to go for a different ECU and no AFM. Rebuilding the stock recirc valve configuration is not hard. You just need a stock or aftermarket BOV with the appropriate adapter for the 2 bolt flange on the back of the J pipe, and to get/make an appropriate ~1" pipe to get the air back to the turbo inlet, and to possibly modify the inlet (if it is not stock) to take the recirc pipe back in. Not hard. Just takes some cutting and welding. Putting an R35 type AFM into the car anywhere is not as simple as just buying the AFM and throwing it in. You will also need to buy the appropriate boss that will then need to be welded onto the pipe where you're installing it. You can clearly see why by looking at the photo posted above. They are not a "simple" swap for a stocker. You can't put on in place of the stock AFM. You can put one in place of the stock AFM, if you get the mounting boss and weld it to some pipe and otherwise make that pipe piece work like the stock AFM housing. Or you can buy such an adapter, either complete with the 4 bolt flange for the air box, or without, for varying degrees of work needed to then make it fit your stock airbox or some pod filter or whatever you have going on. Oh, and the R35 AFM is not plug and play. The wiring is different, but changing that is trivial. The plug is also different so you either end up repinning the original wires onto the new plug, or you just use a short adapter. If you weld a boss to the cold side pipe, the cold side pipe really wants to be 3", otherwise the scaling on the meter can get a bit weird, but whatever the pipe size, it's not as easy as just using the (fully documented in the Nistune doco) simple method for choosing R35 AFM in X" pipe size in the software, because the scaling will already be a bit different. Anyway, all of this has been comprehensively worked through on the Nistune forums, so there is full knowledge available. I would use a Link/Haltech before I would bother putting an AFM into a cold side pipe. That's a lot of effort for a bodge. Nistune is great, can work well even at fairly high power levels, but you are stuck with the limitations of it being the stock ECU, which includes needing to use an AFM, which is not always convenient for every set of modifications. You have to have a think about what you already have, what you want to have, and decide early if you'd be better off jumping ship to an aftermarket ECU. This so you don't waste time and money doing things 2 or 3 times. Never heard of ECUmaster. Sounds like a backyard operation. If there are good tuners for it where you are, and it is a solid product, then it will be fine. We're only talking about an R engine here. Back in the day they all ran on crude nasty early 90s ECUs and they were fine. You don't need a rocket surgeon's ECU to run one.
    • So left off with high hopes of having a gearbox in pretty quickly........ Got the adapter plate that week and had to chase a few threads and work out how/where everything goes as no instructions. Got the adapter fitted, test fitted gearbox and found had to cut and shave a few things. Tunnel required some hits with a decent hammer to give some clearance on passenger side but it fits with no problems,  could fit a 8hp70 with a little more work. For a cross member I wasn't going to spend $1100 on so shiny machined piece. Went through a few designs and remembered I had a gktech s chassis to cd00# cross member. Fitted that and found its close enough with a few extra bits welded so have gone that way and still a work in progress.  After this got into modifying the intercooler with some bends and clamps. I was procrastinating on this as was not keen to cut up and weld it myself but happy with the outcome.  Onto the radiator shroud and oil cooler mount. This thing took way longer than I thought it would but having to add an extra oil cooler for the trans and wanting everything within the chassis rails its good enough for now. It mounts to the chassis and gives plenty of room for lines and pipes. All the coolers are rubber mounted and sealed the shroud on the top and sides, will use some tape to seal the bottom gap of about 10mm. 20250508_111500.mp4   Next job was to build the new diff and after a delay with a friend got built this week. I ended up putting it all together with supervision and was good to learn how to set one up correctly. I ended up going a 3.69 ratio, nismo 1.5 way gt pro with gtr Axel's. Stripped it all down, gave all the parts a good clean, pressed on new bearings and set backlash. Was good working in a clean assembly room with all the gear. Once got home wire wheeled the case and hit it with some rollbar/chassis black paint. Got a few more bits done but will leave them for the next update.
