I have a stock inlet manifold with a pod on my R33 GTST and get that pssshht noise on gear changes/off throttle that I thought was an atmo BOV. Is the noise much more noticeable with the pod vs a stock airbox?
I had a poke around under the bonnet and it all plumbs back into just behind the pod.
It also connects into the boost controller - does this mean that the factory BOV is also the wastegate?
cheers mike
https://www.sau.com.au/forums/topic/149338-factory-bov-with-pod/
the bov has nothing to do with the wastegate.
the wastegate does not make any noise.
the factory bov is plumback and you will hear it revent on gearchange if you have a pod filter filter, as you can hear it echo in the intake pipes
With a stock air box and the complete resonator box with extra sections you shouldnt hear the recirculation/bov noise at all. I didnt on my gtr anyway. If you just have the air box and no resonator box you get a very brief 'dou'..'dou' IE: the begining of a compressor surge noise..
sorry to highjack. I am new to turbocharged vehicles. my fresh imported R33 S2 has what i have been told the stock plumback bov but also has a blitz atmospheric job on one of the intercooler pipes. u can only see it if u take the scoop of the stock airbox off. whats the advantages/disadvantages of this set up? how can i tell if my stock plumb back works? ill try and get a photo
How loud is the "ppssst'' noise? if you have the stock air box you wouldn't hear anything using the stock bov, I'd say that only one of them is in use, So I Don't think you would have any advantage to having them both there!
Edited by RPR33
its not very loud
I bought my car stock and there was no psssstt noise just the turbo winding up, then i got a front mount intercooler and a turbosmart vee port blow off valve and its not plumb back and i had the blow off valve noise, it also makes a fluttering noise depending on how i use the throttle. Then i put the pod filter on and there is a huge difference on the induction noise and with the bonnet up, i reved it a little and u can hear like a wastegate fluttering noise coming from the pod filter... that may be the noise your hearing, coming from the pod?
take my word for it, it wasn't the wastegate that the fluttering noise was coming from.
QUOTE(series2r33 @ 2 Jan 2007, 06:28 PM)
Then i put the pod filter on and there is a huge difference on the induction noise and with the bonnet up, i reved it a little and [/u] that may be the noise your hearing, coming from the pod?
I never said it was?!
Spot on.
Please search function, as im closing this one before it gets too much more incorrect information in it.
This topic comes up regularly... and as usual there are people that are not sure what they are talking about and posting mis-information like.. "its the wastegate flutter", the "BOV is the wastegate" etc etc.
If you are not sure about something, dont mis-lead others.
Thanks.
There is no such thing as wastegate flutter, or anything thats "like" wastegate flutter... as simply put
A wastegate
a) does not flutter
b) make flutter
c) have anything to do with flutter in any sense of the word.
drag-on silvia is correct.
www.howstuffworks.com
If you are unsure, go have a read and understand how a turbo system works.
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
