New Dash Console - Pics
sky017
 Share
did mine last week. first time using a spray can so considering that im happy. how ever i fu*cked up the plastics pretty bad trying to get the rubber coating off so had to use a few (read "many") coats of spray putty before the primer. actually i used primer first but realised it wasnt filling the scratches so i stripped it back to plastic (i think). anyway i mucked around too much and wasnt too careful. hence theres a few imperfections. it'll last till i can get it professionally done though
oh btw, septone paint thinner works beautifully on the rubber...just pour or wipe liberally and watch the crap wrinkle up right before your eyes. naturally i worked this out AFTER i used sandpaper... :P;)
  • Replies 98
Posted Images
Looks fine mate...if your happy thats all that counts, did mine yesterday looks exactely the same minor paint imperfections.... but hey, i did it in the Kitchen........LOL....not kidding, its to cold outside in the garage over here
Hey i am the same,
Just finished mine yesterday in a metallic electric blue looks the part hey and got the thumbs up from my father in law who is a old spray painter and panel beater so i must have done it ok hey post pics as soon as i can figure it out!!!!!!!!!
hey fellas,
mine is work in progress, found a shit load of old cans in my garage so i made use of em, one looked like paint but had a sticker with "primer" on it. done the three coats but im getin the shits with the ciggarette lighter socket thing, the black housing stuck to it for the light bulb doesnt wanna come out so i shoved a tissue in it and sprayed with it on... hope it turns out ok... im stuck on colour now???????? i got a mirror image of sam's. the silver although done excellent but i thnk is too bright for interior...
thanks for all the help guys. gr8 work...
danny. :dry:
hi
my center consol was already painted when I brought my skyline but im in tha process of doing my interior in red velvetin “like pool table cloth”.tha main problem ive com across is air bubbles because of the glue not being applied evenly, but this is fixable I went and got a seringe an will inject tha air bubble with glue so it will soon be perfect. This is my first attempt at doing an interior and I will post some better pics with a non dodgy camera soon if ne one is interested. Glad to answer any questions
Jon from Newcastle
I would leave it for a while sometimes its the moisture in the glue that causes this.
if no joy, pin prick it a few times and wait a day or two..... just incase its trapped air that cannot get through.
then try your siringe trick but not too much glue otherwise you will soak the covering and leave a stain, or a bigger bubble.
Good Luck .....looks mental
Heres a couple of mine in Super Black KH3....notice the Blue perspex on the Clock and A/C so that it now matches the blue LED i Put in the clocks :)
Edited by Allkiller
never thort about air being traped inside because its fabric but ur rite thort cos the glue would make it a seal.thanks for pointing that out . so did u get perspex cut or did u laminate it?it looks mad i wont et.
I used Blue perspex and cut it to shape....works a treat.
or you can use theatre lighting gel to slide in behind the panels.
Tell you what PM me your address...and i'll send you my old ones i modded with Blue gel in em. hows that.
They pop out real easy when you get down to them. Dash off again im afraid.
  • 3 weeks later...
I thought i'd give this a go seeing as my white dash has annoyed me since the day i got it, I ended up giving up after sand papering for a fair amount of time and not seeming to get anywhere...did anyone else have a problem with the old paint not coming off very easily?? I can get through the first layer of paint but then theres a layer of...primer (i think) that is just being really stubborn to my sandpaper attacks :)
Any suggestions as to how I would get it off or is it just a long tedious task and im too impatient? :D
Heres a trip .. Get the plastic primer and spray it directly onto the painted surface.. Wait about 2 minutes until touch dry and hit it with some 400 grit or lower sand paper.. Watch it strip away before your eyes.. it will make the paint sticky and will come off in large thick amounts .. after you've removed most put it in the sun let it dry for 15 mins and strip the rest back with 800 grit and hit it again with 2000 grit and primer it up and paint..
Dont use paint stripper it will melt the plastic id imagine and it will also create a sticky paint ..
Just note I did it on my r34 .. The r34 paint has to be the shittest paint out .. Melts in hot weather and slight presure from a finger makes it run/smudge ..
So if it doesnt work I suggest using a higher grit sand paper (dont use a sander it will cause deep cuts to the plastic which you'll have to sand out) dont go higher than 400 grit as its already pretty sandy .. when your breaking through to the plastic change to 600+ paper..
Cheers mate
Damn, just had a quick go then and it seems to be a no go, unlucky, this particular paint doesnt seem to be as shit as the r34 paint :rofl:
I tried 400 grit, no go, i even went a bit higher...still barely penetrated the outer layer!
I'm wondering if i should just sand it back as much as i can then paint over the top its already gonna be a semi rough job because the other part to my painting is to try and fix a crack that is in my dash thats about 5ml wide. I don't even know how i'm gonna go about this, i fixed up my front bar with some fibreglass, i'm just wondering if i should attempt to use the fibreglass on my dash or doesnt it bond with plastic? Obviously i don't care how rough it will look, but its better than the sticky tape i had over it before :)
If all else fails i guess i can always get a new dash from the wreckers, i'm just looking for the easiest (read: cheapest) way out of this! I'm already missing having my line off the road :D
Edited by Chaddy
 Share
    • Thanks for the reply, So i've continued playing around, and fitted the injector adaptors onto the injector, the fuel rail is not able to be mounted now as the injectors sit a bit further out. I suppose the point of the adaptors is so that the injector nozzle isn't so deep into the intake? I suppose 1mm extra on the o-ring would do it but still can't mount the rail onto the intake haha. Waiting on a reply from Aeroflow I'm sure there's something stupid that I'm missing...
    • EMJ33 or EJM33 - west end
    • I have a radium fuel rail on my Greddy manifold and used the supplied radium fuel injector to manifold adapters (The round green things pictured). I did always wonder if you could just go ahead and use the second lower hole like you're doing... Wouldn't thicker o-rings solve your issue?
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
