New Dash Console - Pics
sky017
 Share
who says you cant drive it with no front panels? Just know for r34 users .. No front panels = no blinkers :S
Neways ..
Yes sand it back to remove all imperfections from the paint make sure you finish with the 2000 super smooth .. lucky you didnt use thinner you would have been in alot of trouble haha.
when its smooth you can either primer it .. i would prob do this just to make sure .. One light coat should be fine, Make sure u sand it back again 2000 grit .. just light sand heavy sand will obviously take it all off .. But the primer also works to remove the imperfections you missed...
as for the crack .. id say best option is to flip it over, use fibre glass along the back to add regidity to the face.. but here comes the hard work .. you going to need body filler.. smear it on let it dry .. sand back. you can use fibre glass filler if you want but its extremely hard to use and hard to stick to plastic!
A simple fix is a soldering iron heating the two plastics together .. do the back first and for the front push the plastic in to make a crevis .. then apply body filler, dry, sand, spray putty, dry, sand, re-apply, dry, sand, primer, paint .. check if its good enough ... if not repeat!
Best of luck dude
  • Replies 98
Posted Images
thanks for all the tips you wonderful people. i am through 2 coats of paint at the moment and its turning out gorgeous.. and to think people pay 100 bucks on those plastic dash trims when you can get this done for $35! simply brilliant .thanks to the topic starter and to all those who shared knowledge. Cheers
Finally finished painting mine after endless problems... Sanded back on a windy day so was getting the powder in my eyes. Primed and sprayed just drying over night waiting for gloss coat, apparantly it was very windy as there was a fine coat of bugs and dirt so i sanded it all back and started again. Turned out great though, matches my exterior paint perfectly.
just waiting on my gear and handbrake gaiters and its all set(mr gaiter on ebay, make sure to check him out, $70 gets you a custom colour design gear and handbrake gaiter set made specifically for an R33)
Edited by Baconer
300km/h :P
Go to the group buys section, Amec is selling R33 white face gauges for 100 a set
yea ive already got el dials on ... but just 180k ones.. urs looked like it goes upto 300... or is it just not been recalibrated?
Because it does go up to 300k :(
Has been calibrated but stock computer so doesn't go above 180
any1 got a pic of what the blue LED 300km dials look like?
Its one of those have to see in person things, i have blue LEDs behind the whiteface gauges but the pictures dont do it any justice. It looks bloody great though :D
Did mine the other day using Tamiya model spray paint. It is designed for use on plastic so no priming etc.
I just removed the coat of rubber from the dash (what a pain!!!), cleaned it with wax and grease remover and gave it 3 or 4 light coats.
For those interested, the code for the Tamiya paint is TS-40 (metallic black). It has a very subtle metalic fleck and cost $12.99 per 100ml can. I used 3 cans in total. Very happy with the results, as I was after a stock kind of look.
Model paint is actually lexan paint dude .. If you applied a primer it wont stick .. if you didnt it will never come off as it fuses with lexan .. However with plastic im not sure .. Best thing about lexan/model paint is it is heat proof up to about 300 degrees
No, I didn't use a primer. It sprays on beautifully in really nice thin, even coats and isn't too glossy like normal spray paint. I love it. I also did my interior rear vision mirror. That terrible grey colour was pissing me off. Having a black car it stuck out like dogs balls every time I looked at the car from the front.
hey guys im a brand new skyline owner.
was lookin through this thread, some awesome results here and seeing as how my interior is a bit rough i just have to do this too.
ive got a bit of a noob question though... how do i remove the dash panels? i dont wanna break anything so i thought i'd ask first.
I'm thinking a dark silver might go well with a black skyline. What do you think?
thanks!
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
