Cruise/BBQ and just a day out!
:cool: Im going rain or shine but no hail (that would damage the car) :w00t:
Meet: 9.30am
At: North Parramatta Dick Smith carpark, map below
Church Street then on to cumberland hwy and then the m4/great western hwy...
Leave at 10.15am sharp!
Going to: Wentworth Lakes (Wentworth Falls)
If you have a 2 way radio bring it along, makes for easy communication between cars whilst on the road.
Cost: $2.50 per person to cover food and drink(please bring correct amount)
**PLEASE ADVISE HOW MANY PEOPLE WILL BE IN YOUR CAR JUST SO I GET ENOUGH FOOD**
Post your name and car type if Your interested in coming along...
Want a big turnout!!!!
GOING
DANSR33(Danny) - R33 GTST
Bill - Porsche 928 5L
Aaron - Holden VN 5L
Dj Albert- R34 GTT
Garth - S14 200SX
Ali - 300ZX TT
henzie - R33 GTST
henzie's friend - 180SX
skylinegtts - R32 GTST
Abo Bob - R34 4door GTT + 3 skylines
s1kr33 - R33 GTST
rwkw(Rob) - R33 GTST
chris - R32 GTST
D3LTR33 - R32 GTST
tjandriesen - R33 GTR
Oz GTR02V(paul) - R34 GTR
Trust33(craig) - R33 GTST
Dead32(Ryan) - R32 GTST + 5-8cars
Yts(Jeremy) - R32 GTS4
Alien - WRX
JSL(James) - R32 GTR
Liquid(Craig) - R33 GTR
wokburner - 300ZX
Marsss - R33 GTST
OSH33N - R32 GTST
julion - R32 GTST
Edited by DANSR33
https://www.sau.com.au/forums/topic/149342-blue-mountains-cruisebbq/
  • Replies 94
Thier is parking for probably around 20 odd cars in the small off-road carpark. However you can park along both sides of the road which is a very quiet road.
Shops are about 500m from the Lake (at the highway) and their is also a small park with playing equipment if anyone is taking kids.
so you in Ben?
No i'll be at the summernats, besides I work up in the mtns every day so sorta seen enough of it :)
Their isn't much 98 octane fuel in the mtns either so make sure u get a full tank before leaving home.
thats unfortunate.... :laugh:
Will make sure to get a full tank before leaving... hehe
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
