usually this happens in front wheel drive cars where people do too many handbrakies and the thing just stays on due to a broken switch. In ur case it might just be a fault, electrical. its not a fuse cos the light wouldnt go on at all if it was. U might have to look up where the wiring for it is so u can fix it
https://www.sau.com.au/forums/topic/14936-handbrake-light/#findComment-303611
aah ppl
i had this problem ages ago
and i thing u's are all looking at it to deeply
it will most likely be the handrake cable running from handbrake to dash
all u need to do is find it and under handbrake stick, it will be thin white cable with red stripes through it
adjust it a bit and u will find it will fix that problem
https://www.sau.com.au/forums/topic/14936-handbrake-light/#findComment-305813
The handbrake switch is an earth switch, basically when you pull up the handbrake it completes the circuit to ground, put it down it breaks the circuit.
I had this problem a couple of days ago. Turns out there was another wire spliced into my handbrake light signal wire which had been hooked up to something in the past but wasn't any more. The connector on the end of the wire was shorting against some metal work and bypassing the switch, result was handbrake light on permanently.
You've probably got a short somewhere which means the switch is being by passed. Unplug the switch and if the light stays on you'll know for sure. It only takes 2 minutes to pull the centre console off and try it.
https://www.sau.com.au/forums/topic/14936-handbrake-light/#findComment-309821
A bit off topic but you might be interested to know that my handbrake is hooked up to my turbo timer, so if u take the keys out and release the handbrake then the timer straight away kills the engine. Perhaps this explains the mystery wire...?
https://www.sau.com.au/forums/topic/14936-handbrake-light/#findComment-316198
  • 4 weeks later...
G0DF4Th3R, did you sort this out? I got the exact same problem the other day - handbrake light went on when I was going around a corner, then stayed on for about 15 minutes then went off again and has been off ever since. I was thinking it was a sensor detecting low pads, or the brake fluid level as has already been discussed.
It seems too freaky a coincidence for it to be something like a short. Out of all the wires in the car, what are the odds that I have the exact same short as you in the handbrake switch? I think it's gotta be something else.
https://www.sau.com.au/forums/topic/14936-handbrake-light/#findComment-356458
