how many of you have 18 by 9.5 under the rear of r32 gtst? i wana get teh deep dish impul rear for my car. as atm i have 235 allround. looks ghey... height isnt an issue as i have coilovers i could raise im assumin i need to lip guards etc. any suspension arm issues.
https://www.sau.com.au/forums/topic/149387-95-wide-under-gts-t-r32/
Offset? But the rear has heaps of clearance to the strut. You should only have guard clearance issues.
I've had 18x9 +45 on the rear before and there was still plenty of clearance to the strut with 2.5deg camber
Edited by salad
I have squeezed some 17x9.5 ssr's under the rear of mine. You really don't have a lot of room to play with.
The effective offset on mine with spacer is +46 as i removed the original 15mm spacer that bolts to the back of the rim and replaced it with a 5mm slip on to fit it. Ideally it would need an offset around +43 give a bit more clearance to the tie rod end and coil over as it is really very (too) close atm.
You will need lipped guards minimum running 235's, probably slight flares to run any wider tyre without scrubbing problems. If the tyres have the little lip to protect the edge of the rim it will be even tighter
Are some of you confusing the front and rear? I currently have 9.5" wide +38 rears on my car and i do have rolled rear guards. They clear everything nicely. I dont know how they would go with wider rubber or unrolled guards, but i think its pretty safe to say you dont need to lip the guards
i got 9" with 255s(gtr offset) on the rear of my gfs gtst
Wow.... :)
What width rubber do you have on yours Troy?
I've got +38 offset 9" wide with stretched rubber (235) and there is a bit of clearance but my suspension is so stiff it doesn't even go close.
What is the correct width rubber to put on 9" and 8" rims?
Mine at effective +45 offset, 2 degrees camber and 225 bridgestone semi slick. Straighten up the wheel and increase the offset by another 8mm and they'd stick out like dogs balls, plus scrub with a wider tyre.
Sorry about the picture quality, camera phone in night vision plus me with the shakes = bad photo. Just as a reference, heres one of the front showing the thickness of the lip. That may be why mine were a bastard to fit under the guards.
russ i have 18x8 235/45/18 on front of my car, never rubbed with old suspension, however coilovers on it now and it sits alot lower so it rubbs. i reakon alot of this has to do with just how low the car sits..
I have 255/40s on my 9.5" wheels and they are a tad under the correct width. So i think they are the perfect tyre for the rim. What i look for is that when i put the rim flat on the ground the face of the rim touches the concrete and not the rubber.
hope you're not a curb touch parker!
Roy i have 225/40s on 7.5 inch wide rims. SK suggested i run 235 in the future. Why do u like the tyres stretched out, i mean wouldnt a 265 provide more grip and a better ride?
Edited by 2630GTS
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
