Oh I must've misread. I swear it said 255? Ohwell, my mistake.
I would stick with 225/40 on there. 235 is a bit big, and I dont like it. But Gary likes to get as much rubber as he can on the rim, he puts 245s on 8s.
I've got some 17x9 +20 that I've put all round on my car before, they stick out ~20mm, so you need to do a fair bit of guard rolling. It looks damn tough with the offset though, clears all the suspension easily. I had 215s on them at the time though, so I'm not too sure how 255 would go, but I was looking at the edge of the rims. I can send you some pics of how they stick out if you want?
Salad how do u think 18x9 +22 would fit on r32 gtst? with 255 rubber?
LOL...no hope. Unless you attack your guards with tin snips . :D
I currently run 235/45/17 RE55s on my track rims. The RE55s are a bit wider then most 235s. If i drop the rim/typre on the face the rubber overhangs enough to protect the face of the rim. Now a few ppl i know have gone from 265/40 on GTR rims which are about the same fit...to 255 which are a tighter fit, must like my street rubber 255/40/17s on my 9.5" LMs. They all agree the car is quicker, and handles nicer. The lap times are not wrong.
So next time round im going to try 225/40s on my 8" track rims rather then the 235s.
Thanks for the help.
My choice is either 18x8.5+40 or 18x9+22.
I think ill get the guards modified, i know someone pretty handy. I guess fitting gtr front guards would be an easy option on the front.
Salad has said previously that the 8.5s with +40 will hit the strut(front only) with the tyre if not the rim. I want to run the same size wheel/tyre combo front and rear, hence why i just bought the 7.5 + 30s for a start :laugh:
Cheers guys
Edited by 2630GTS
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
