  • Replies 2.1k
Posted Images
ummmm... yeah
wtf?
Honda F1 introduces elephant ears
03 May 2007
On the final day of testing Honda introduced a radical wing on the nose of the RA107. Honda's test driver Christian Klien is out in the car today at Circuit de Catalunya today to test the new 'elephant ears'. Whether or not the Honda Formula 1 team will use the new wings during the upcoming Spanish Grand Prix is uncertain at the moment. It is interesting to see though the team saved their new wing to test it on the fourth and final day of testing
Another good reason to cut aero as much as possible, they make the cars look damn ugly. Was looking at pictures of the 88 Mclaren (MP4??) and it is simple and elegant and beautiful.
The 88 McLaren was the MP4/4. Actually all of Ron Dennis' McLaren are part of what he called project 4 - needless to say the first three didn't work nearly so well. The car itself was designed to a fair degree by Gordon Murray & a number of others who's names don't immediately come to mind. I think John Barnard had either gone or was in the process of going to Ferrari.
Anyway with two hacks by the names of Senna & Prost the thing won 15 of 16 races that year.
For my money, however the prettiest McLaren of all (M6A aside) was the MP4/13 which in pre-season testing wore the traditional McLaren orange along with the West sponsorship logos.
yeah I saw the BMW F1 nordshlieffe laps on TV. looked awesome, but damn, 8min 34 seconds??? did he park on the back straight and have a quick smoke?
I read something on F1 live that BMW 'dummied' the car a little bit. Harder compound tyres, increased ride height and brought the motor's max revs down, apparently it could still do 300km/ph, but cornering and high speed balance/grip was lowers so it wouldn't be so 'dangerous'.
No offence, but I wouldn't mind seeing Monaco off the season list.... Keep Silverstone!
Bring back the twin German GP's!
Oh yeah, Singapore has been confirmed for 08 as well!
If anything, I hope one day we'll see Zandvoot again, great racerack!
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
