  • Replies 2.1k
Posted Images
Or they could just fuel him slightly less so that he qualifies slightly higher (5-8 instead of 8-12) so that he has better track position in the first stint because it's easier to hold someone up behind you than it is to overtake someone doing a similar lap time.
yeah good point. but i think the problem with that he may not actually qualify better than that with the same car and setup.
team stratergy will work out. it will fall into place at some stage. Almost did in canada.
Quoted from greman newspaper and translated into english...
Sounds like a typical Joe Saward piece of bullsh!t. He basically makes up whatever he wants & reports his opinion as fact or occasionally as conjecture. More often than not he is completely wrong.
As the quote goes "Writing fiction is great, you can make up just about anything."
He is one reason why I never used to buy Motorsport News. Although now you don't have to pay for it.
It does explain to some extent whay we havent seen any sort of aero upgrades recently... Mclaren, BMW, Williams even Honda have introduced parts recently. You'd think Ferrari would be right up there pumping out aero pieces to keep up with Mclarens rate of development, but no. This week is the first week in some time that they're adding new aero parts on the car.
Just seemed like a logical explanation...
Well it's plausable. Which is the kindest thing you can say about some of his stuff.
Unfortunately for peeps like me Ferrari are dropping the ball in many areas this year and it starting to show up now the season is getting serious. I know of maybe a big aero upgrading coming but not until August which is way to late in the year. I think maybe some of those key members leaving is starting to filter through
Im with you there, typical Mclaren, more data for Dennis's mob. Calling Honda a 'B' team is a complement going on there discraceful performance this year...maybe the 'Z' team would be better.
Well it isn't actually Ron Dennis' fault. More of a case of getting a deal done whilst he cane & whilst it can benefit McLaren. The rule shouldn't have changed - each entry should be required to use a different constructor. Back in the day companies such as Lola & March supplied heaps of chassis.
& yep Honda suck wang this year. Hopefully they will improve.
Lewis Hamilton stacked his Vodafone go kart at an event today!!
ahaha, lets hope thats the only wipeout he has this year!! it was a total noob mistake! :laughing-smiley-014: :laughing-smiley-014:
check it, helmet cam style. :D:)
http://www.youtube.com/watch?v=K_4uhYoMEX0
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
