Whilst getting square eyes I stumbled on a string at Probe Talk about modified side feed Nissan SR20 injectors for the Probe V6 .
They claim that these Nissan side feed injectors have a cap with four small holes spot welded at the business end , if this cap is removed you find a single pintle valve that gives a nice pattern and a garden variety NA SR 20 injector of 270cc suddenly becomes 550cc . Some jem from George Dubbyaville worked out that the mod gives 2.15 times the std flow rate which is a bit interesting eh ? I could be wrong but the 370cc version gave I think up round 740cc . The KA24DE (DOHC 16 from US spec S14) must have 440cc squirters and ended up in the 800's somewhere .
Do a search on shaved injectors but have plenty of time to read the posts .
Is this stuff well known about or just new to me ?
Cheers A .
Edited by discopotato03
https://www.sau.com.au/forums/topic/149409-shaved-injectors/
  • Replies 80
disco: a while back i bought some direct replacement 550cc injectors from the forums here, when they arrived i noticed that they were EXACTLY the same externally as the set of RB25DE 270cc injectors that i have here. i mean same colour, same markings, same numbers and everything. i was initially annoyed because i thought i'd been ripped off, but upon looking closer i found only one difference between the two injectors - the tips.
the bigger flowing injectors have a single large pintle, whereas the N/A injectors have the four tiny holes as you described.
i assumed that the guts of the injectors had been removed, and fitted with a single larger pintle. it does look to me now that you can remove the very end of the N/A injectors somehow - i will rip one apart tomorrow and see what i can find. it is very possible that this is what has happened, the 4-hole cap has been removed, but i'm not 100% sure yet.
i'll let you know tomorrow if i remember to pull this injector apart.
this has grabbed my attention, if stocky can get some pics of the injector before and after it would be great as i don't have any spare side feeds here atm.
as for spray pattern, we would only be guessing as to how poor it may or may not be, alot of factory injectors that are single pintle have less then optimal spray patterns anyway, it would need to be tested i guess.
More searching to be done . I remember one convert saying that they were getting good spray patterns and factory std idle so looking good thus far .
Acid test will be testing along side a factory high flow injector ie Nippon Denso 555/740cc injector .
My FJ20ET had single pintle Bosch 403 550cc injectors fitted and I think some top feed RX7 turbo injectors are a similar thing but high current low resistance .
Would really like to see if end caps with set hole sizes can be obtained to retain the multi hole spray pattern .
Cheers A .
So far good reads at :
1) Probe Talk - "How to get 550-600cc injectors for $100 - for our stock rails"
2) NASIOC - "740cc injectors for free"
Some people in the US are claiming that Nissan side feed injectors are all the same but with caps of different sized holes to graduate maximum flow . Makes sense if the only difference is the plastic dye and end cap .
They seem to be using Pink Red and Blue/Grey colour coded injectors and with the cap off claim 440 550 and 880cc flow rate at I think around 43 Psi .
There is some kind of injector from a "KL" whatever that is that even has a plastic cover cap that aims the stream at each inlet valve but need more time to look into that one .
What Arnie said , cheers A .
guys i just went and cut apart one of my N/A injectors here in the garage, took some photos but you can't really see anything properly so i'll just tell you what i found.
the single pintle injector on the right is my 550cc injector, the one on the left is a factory RB25DE injector. they look the same and have the same casings etc, the only difference appears to be the little end cap which has the four tiny holes as per photos above. post-14902-1167697148.jpg
the cap is very thin steel but is spot welded to the tip of the injector in a very neat (and very strong) manner. i couldn't remove it easily, so i had to cut it off with a hacksaw until i could remove the whole piece in sections. unfortunately this resulted in the end of the injector being rooted as well, as the depth required to hacksaw to remove the cap was too great. it's hard to explain in words, i wish my close-up photos had tuned out but they didn't.
it appears as if the single large pintle in the injector seats on the back of the cap. this would make sense because if it didn't, then there would be a small section of liquid fuel sitting between the two which would ruin the pressure differential and thus spray pattern. if the pintle seals against the cap with the 4 holes, then as it unseats off the back and the rear of the cap is exposed to full fuel rail pressure, the 4 holes would act to atomise the fuel fairly well. they are pretty tiny after all. what would be interesting would be to compare an RB25DE injector with an RB25DET injector, and see if the 4 holes in the end cap are larger. this may be the only difference, i'm not sure?
anyway i hacked the rest of the thing apart just for kicks, it's all pressed together so i'm not sure how you would disassemble an injector if you ever felt the need.
what i think has been done with mine is that the end cap has been removed with great precision, and then the tip of the injector pintle has been re-seated on the casing (again, hard to explain, easy to see). this might then allow the thing to have a decent spray pattern with the cap removed.
i'll have the things flow tested in a couple of months i hope, so i will see what the results are like then.
cheers
Very intresting... this may save some people a LOT of money... anywhere i sydney that can "highflow" the stock RB25DET injectors?
I contacted Power Flow in wetherill park and he quoted $800 for a full set of 550cc "highflowed" RB25 injectors... which i would rather get the Nismo's
Cheers
contact DeatschWerks [[email protected]] they can do a set of highflows for around 600 delivered and pay $25.00 US per injector core if you return your old ones to them, works out $178.00 AUD return in the end and so far no problems yet very reliable as well and works out the cheapest method that is for a set of 550 highlows with average around 542 minimum to 547 max CC flow id recommend them,
Cheers Adam
There turn around varies as with fedex couriers, for instance may take upto two weeks which is normal for fedex from the states to here postage, as with return for your money well, it took 4 week via airpost australia for my injectors to arrive and also for my payment to arrive to me via paypal which again i would consider normal aswell, but dont limit yourself they are available in all sizes from them.
Hope that helps
Cheers Adam
Again i must say that they do come with accurate flow sheets with all data refering to each injector which is another garantee of accuracy and dedication to there job.
Edited by Devils_Advocate21
well like i said earlier i linished a stock sr20 injector taking the cap off witht he 4 small holes revealing the large pintle.
I went to my friends work today and flowned them, with it linished flows around 780 cc with was at 50 psi
Edited by GTR1993
Had a little go at this today with my day off work. Used rb25de injectors. Thanks very much for sharing this too disco really good info.
I have 2x sets of rb25de injectors so I had a muck up go on my shit ones's and will do my existing ones better tomorrow. Here are some pics:
Dremel action:
Before:
After:
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
