hey people im not sure i know any of u but i knew possum a little.i met him at the forest rally in perth and spent some time with him at hq afterparty,, as im into rallying myself as a job and hobby i will definately be attending anything to do with his honour. GO POSSUM!!!! menios from extremedriving.net
https://www.sau.com.au/forums/topic/14941-tribute-to-possum/#findComment-308392
Lozza, I'd suggest posting a new thread in the NSW Events section with date, time and location.
FYI - Carlo and I posted a request to join their cruze on the MRT Subaru forum - There were no objections - so I reckon that would be appropriate - I also reckon that following the Scubes on the day would be appropriate.
https://www.sau.com.au/forums/topic/14941-tribute-to-possum/#findComment-309870
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
