Good Idea.... I read all that. I honestly thought they would have been against it. I feel there will be some Angst (tension) beteen the two parties. Nothing bad, just who's is better sort of stuff.
Yes Follow would be better
Cheers
Loz
to be honest .... the subi boyz are just feeling inferior to 2 extra cylinders,, i say turn up if they dont seem happy bash em and burn their cars to keep us warm.... on a serious note possum is the name of the game ... if they want only SUBBIES to go there obviously just using posum as an excuse to cruz and really have no respect for the whole reason they are even gathering.. i like the stuffed posum idea on the roof of the cars ... even a little subaru flag on antenas or sumthing to justify to the public WHY where cuzing with subarus...
to the other questions...
im fine yes thank u ..
and i was lucky to get this job i know
and im really learing alot about stuff,,
mad u should be doin it with mathew apps ...
if its this weekend commin hes got the group A evo 3 ,, its currently under my repair at the moment so he wont take that but if its NEXT weekend i beleive hes going testing in it and i might be their ... this weekend im relaxing at home.. cheers
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
    • There's another sensor that sits inside the evaporator, that's a C U N T to get to, but can be done without removing the entire unit. Usually it's not the sensor that dies but the actual capacitor in the circuit (part of the plug that dies).
    • Putting the climate control CU into diagnostic mode is independent of the ECU. You just have to do the dance prescribed in the manual. No, I do not know what the dance is. I have an R32, so use the dance in the R32 manual. On older cars, I would have said "no, the ECU should not affect whether the A/C works".... but for an R34 that might be wrong. I don't recall the detail, but there was extra mods required to make my R32 A/C work against the R34 ECU. The R34 ECU apparently gets involved in the running of the A/C more than earlier cars did. Theoretically, if the PFC is a true plug in, then it should just work the way that the original ECU does - wrt A/C. But there's always scope for them to have not cared. Nope. Pressure switch out = getting the fridgey out to pump the gas out before pulling the switch. The switch really cannot sense gas pressure unless it is up against the gas.
    • Hi guys, thanks for the replies.  I will have to wait till summer to test properly, but it short cycles both when heating and cooling. I’ve ordered a new internal temp sensor that sits under the vent in the steering wheel also, GTSBOY, I have an Apexi FC ecu, I’m assuming I won’t be able to diagnose or would it still work? Could the ecu be causing the problem??   the pressure switch is quite cheap I will get a new one and try it out, hopefully it doesn’t require purging the refrigerant again?
