  • 3 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
Ok Update time!
At long last, me and a few mates installed my coilovers for the SAU Track Day at Wakefield Park, G4 Racing Street Spec with height and damper adjustments The Handling has improved heaps without compromising the ride too much. Best mod to my Skyline yet! My lap times at Wakefield have gone down to 1:18.6 Pics of wakefield to come
Pics:
Front
Rear
On Hoist
On The Ground
hey man- nice 33 4door i have the same model in dark blue-green cameleon (spelling). just had competition spec springs and shocks put on, and its only about than 1/2 inch higher than what could have been achieved with overcoil- so think about whether its worth the extra grand or so before you go all out- being a show car and not for drift i didnt need it- neway man nice wheels so far and im sure u'll think of plenty of things to keep it different! peace
Its certainly coming together. You have to be happy with the night time pics over the harbour, looks great.
If I ever do another road trip to Sydney I might have to drop you a line and organise some pics. :P
  • 4 weeks later...
note to self- do not post replys when drunk.... haha didnt realise u already had installed the suspension how much did it end up costing?
Hahaha. thats ok. It cost m $1299 for the set and $100 for labour.
If I ever do another road trip to Sydney I might have to drop you a line and organise some pics. :down:
Thanks Jason, shes actually up for sale now :thumbsup: I know i'll kick myself when it sells, its such a great car.
For sure if u are ever in Sydney i'd love to do it. I'm actually heading to the gold coast in October for indy but my car is staying home if it doesnt sell by then.
Since you enjoyed the pics from the harbour, heres somemore with the car lowered.
  • 1 month later...
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
