Hi
For sale is S15 calipers and rotors.
Callipers are in perfect working order with standard looking pads (not sure).
Rotors have seen better days and have heat spots on them and warped. I haven't measured the thickness but they are probably close to minimum size. edit: rotors are 28.3 mm
Kind of wierd but they were on my R32 GTSt when I bought it and I'm pretty sure they are the same as standard R32 GTSt (280mm diameter). I'm not sure why they were on it? Anyway 100mm bolt centres and fit almost all nissans from the same era.
Reason for selling : Upgrade
I want $300 for the calipers and $25 for the rotors. Calipers now $220!
Also for sale driver and passenger seats from a GTSt.
Really good condition. Only problem is that the plastic on the passengers side where the adjusters are is not held in by the 2 bolts. (little bit of plastic is broken off and it doesn't sit right)
I would like $75 for drivers sid and $50 for passenger. or $100 for both. Now $80 for both! SOLD
R32 standard diff centre. I bought a diff complete and put a spool centre into it. The viscous centre is what I'm selling out of that diff. In very good condition when I pulled it out and the guy said that it never open wheeled on him when he had it. 80,000 km's I was told. $120 SOLD
I'm working in country victoria on 2 week stints so I'm home every 2nd weekend for inspection and pickup.
PM, Post here or give me a call 0421332860
Thanks,
Russ
hay mate,,curious as to were you got a spool for a 32 diff and how much are they
also are they different spools for lsd vs vlsd
throw us a pm
cheers
Hey man
the spool was in the car when I bought it from Japan and I just had to replace the diff that surrounded it, centre was fine.
I think they are generally cheaper than power lock LSD's like 1.5 and 2 ways but there are down sides. Mostly understeer induced by the diff wanting to go straight ahead. It's damn strong though.
I think I would prefer to have a 2 way but this is what I got and it works for what I need it to do.
I'm not sure if there are different brands or different types for lsd's or vlsd's but I reckon they are all about the same. It just locks both axles together. Nothing fancy about that!
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
