if it makes the weird thump when its meant to be playing it generally says that either the amp's channel that your running off is playing up and sending an incorrect signal or that the amp itself is tuned way to high for the recommended setting of the sub.
btw has it only just recently started to make the noise or is this from a new amp/sub set up?
if your located in the northen burbs of melb your more than welcome to bring it round to my place and i can have a look at it.
Edited by cheez
thanks for offering to fix it, but i live in sydney... the problem has only just started to play up... i will try re tuning it
thanks heaps
When I started to hear distortion in my car I originally thought I had blown a rear speaker. Turns out it was the sub, the cone had separated from the rubber surround.
But really this could be a lot of things. Try another sub if you have one/can borrow one, that will rule out your sub packing it in.
Fixxxer :laugh:
  • 10 months later...
Fixxxer :D
ive got the same problem at the moment i call the dude that installed my system he rekons its the amp sending sme signal or interferance somthing like that anyway
lucky its still under warranty so now ive gota take it bak to moto quip and they will send it off then i will knoe whats wrong i guess ill try my other fusion sub just rule out the sub
shiting itself any info would be great ppl if you have had the same prob and fixed it.
Cheers
Allan.M
alright, so im assumung that when you listening to music, the sub just randomly starts thumping? few things you need to check.
1 make sure that your rcas arent shorting out anywhere.
2. make sure that they are plugged in securely to the headunit, and to the amp
3. make sure that the amp is grounded properly, and is receiving sufficient power
4. ensure that all your speaker cables are secure, and arent shorting out.
if this doesnt fix the problem, then take the amp out, and try it in another car. if it still does it, the amp is most likely fuxxord
cheers bud its under warranty wiring is fine thats the first thing i checked was the rca ant that so i will get my amp back in 2 weeks
cheeers
Allan.M
    • Yeah, the thread is only nearly 20 years old.
    • Been down in Tassie for 2 weeks (a cruise, not a race for once) but spent a little time on her when I got back. I worked out the injector settings in the PowerFC were not correct for nismo 555s, set those to 66% +10ms and added a little air at closed throttle, set the timing (approximately, because it has some weird non 15o cells around idle) and now she starts and idles properly. She purrs like a kitten (ignore the co2 alarm in the background, I did  ) 20250518_171052.mp4 Next step, off for run-in, tuning and alignment!
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 馃構 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
