hey guys.
Havind just purchased my car, stock 96 R33 gts-t, i would like to make it sound nicer. In a month or two im planning on getting a full turbo back and cooler, but for now, how do i get some induction noise? can i just put a pod filter on it? i dont want to spend much to be honest, hardly anything. a specific brand? could i just rock up to autobarn and get one? Price? Any ideas.
Sorry for such a newbie thread.
Thanks for your help.
https://www.sau.com.au/forums/topic/149445-how-to-get-some-induction-noise/
if you put a pod filter on , your car will become more responsive as far as sounds . the stock air box is heaps restrictive . you will get heaps of sound , and your bov will sound heaps louder . car will make a wshhhhh sound .
cheers
apexi pod filter ftw - i think the one u want is the 022 model (i think) - got mine for around $150 fitted @ RE Customs. Autobarn has k&n stuff - good filters, but the reviews for the apexi were better...
you'll probably need an adapter plate to go from the four bolts of the afm to the circular pod
the apexi pod (022 model) will bolt up to the afm straight. if sillylankan choose to go for other brand, he will need them.
ok thanks guys, let me get this straight, if i go to autobarn and get the k&n filter ill need to get addional stuff, but if i get that apexi one, it just bolts straight on?
cheeeeeerrrs
cheeeeeerrrs
yup for K&N you will need an adaptor plate. Apexi bolt on straight onto the afm.
Mate, Ill swap you my massive Blitz pod filter (Lots and lots and lots of induction noise) with adapter plate and support bracket for your factory airbox and snorkel. If your keen PM me, I live in Sydney.
Shit u live in Melbourne... My bad :laugh:
Edited by Chris_R33GTSt
Shit u live in Melbourne... My bad :)
from my personal experience they are a lot louder than the apexi ones, not mentioning their poor filteration result.
to make the best sound:
dont run any filters at all...just take everything after AFM off, and the car sounds really really really really loud.
caution: it could cause long term damage.
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
