if you put a pod filter on , your car will become more responsive as far as sounds . the stock air box is heaps restrictive . you will get heaps of sound , and your bov will sound heaps louder . car will make a wshhhhh sound .
cheers
pod=wank effect!
stock airbox is fine
in most cases a pod will make u lose power. GTRs are well knwn for that. sigh.. hence its still an airbox. and will stay that way.
how is it that an apexi pod is better than a K&N.. better noise?
better noise = thinner filtering walls
well i would figure that the K&N would be more effective as they do nothing but develop filters. unlike apex'i that have wank products too.
I just finshed putting the stock airbox and stock bov back on mine, the noise just got annoying and in fact I like the sound it has now, its loud enough with a 3.5"all the way through...
I think my driving car is loud enough
lol thanks for the info guys.
alright say if i had a pod for a month, and after i got the cooler and exhuast installed, would it be a good idea to remove the pod and put the standard airbox back on?
^^ no you dont change anything..
Buy your pod.. LEAVE IT FOR EVER!! Lol...
You will need a cold air box also!! Use one that uses stock snorkle.. Or think about which fmic you will be getting in the future..
That is will it use stock piping route (then you will need a cold air box which uses the stock snorkle) Or if the piping goes the other way then get a full inclosed cold air box, and use pvc piping from the bottom to feed in the cold air..
then get a full exhaust system, and a FMIC!!
K&N are supposed to be pretty good in terms of filtration. Theres an air filter review in this months Autosalon magazine. Ive got a Green Cotton pod which is pretty similar to a K&N, theres a website somewhere that compares Green Cotton to K&N (Green Cotton is supposedly better...).
I was reading Auto Salon Mag issue 51 and it had filtration and flow tests on heaps of pod filters... Results were suprising!
The flow test was done on Smiths Engine Research's flow bench.
AEM Dryflow : $100
FLOW : 9TH
FILTRATION : 3RD
APEXI Power Intake : $125
FLOW : 7TH
FILTRATION : 6TH
HKS Direct Drive : $125
FLOW : 6TH
FILTRATION : 9TH
K&R RR-3301 : $125
FLOW : 4TH
FILTRATION : 1ST
REDLINE Airforce 1 : $40
FLOW : 2ND
FILTRATION : 10TH
SIMOTA Power Stack WS-002 : $29.95
FLOW : 3RD
FILTRATION : 5TH
TENZO WS002-CH : $19.95
FLOW : 8TH
FILTRATION : 4TH
3A RACING : $28.95
FLOW : 1ST
FILTRATION : 2ND
TRUST Airinx : $120
FLOW : 5TH
FILTRATION : 7TH
NO NAME (Trust Imitation) : $15
FLOW : 10TH
FILTRATION : 8TH
They said : 3A RACING, in all honesty, to begin with we thought the 3A Racing filter wouldn't be a top performer. Its certianly nasty looking with its yellow and red combination. Upon testing however, our doubts were turned on their heads as the unassuming pleated filter punched out huge figures. With the highest airflow of the bunch and the second best filtration this is definatly a clear cut winner.
If you want a louder induction noise make sure you stop your bov from leaking or get another one... it make's it scream that little bit more coming on boost and yea a pod helps with the induction noise too... besides unless your going to build a 10sec car i wouldn't look into things too much man... just do everything properly and speak to the right tuners..
i was reading a engineering report, and apexi pods are better made than the k&n ones. who said they are loud? they dont make half of the noise the biltz ones i had....they are far from loud.
http://www.mkiv.com/techarticles/filters_test/2/
There ya go buddy :P
Apexi ftw
Btw a alluminium intake pipe rather than the rubber POS will increase ur induction noise quiet abit, but do that after fmic/exhaust etc
Edited by jazza08
A pod is an important thing (or any air filter) its the life of your turbo and engine. By the sounds it seems that u want to skimp on cost for this. Maybe wait until u have more coin n get a decent one that at least filters well.
I was reading the results on this website http://www.mkiv.com/techarticles/filters_test/2/ and it was saying that it actually increased horsepower??? Correct me if im wrong but an exposed pod in the engine bay will infact suck in hotter air hence reducing power and with less filtration properties than the stock box even cause damage to the engine by letting in more foreign particles and cause detonation due to increased stress on engine?? What are the opinions on this.
hey guys
went out to autobarn and got myself a k&n, installed it just before, induction sounds awesome. surprisingly the factory bov isnt all that bad.
thanks for all your help
I realise that you have already purcahsed an K&N setup however I wouldn't recommend using them with any vehicle that uses an AFM or AMM, including all late model skylines. These filter use an oiled element which has the potential to distory the wire contained within the AFM.
If it helps anyone I can supply A'PEXi Power Intake filters and our own mounthing kit for $136.50 delivered, details can be found within the following thread:
http://www.skylinesaustralia.com/forums/in...howtopic=143874
ive read a different air filter study that put the trust airnx on top. how could an oiled filter be good for a hotwire afm?.... my 2cents p.s i dont know how you ppl hear any induction noises lol. maybe my 3.5inch exhaust is just a lil louder?
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
