Increase value = sell skyline and invest in a house.
most things you do to your car will always depreciate, unless you keep it mint and no one else has it. then it becomes a collectors item.
increase speed = cut wire 53. more money you have the faster you can make it go.
if your going to keep it for 6 months only, keep it stock as possible and keep the k's low for better resell value. if you want to sell it quickly then you have to sell it cheaply.
https://www.sau.com.au/forums/topic/14946-newbie-needs-help/#findComment-304025
Originally posted by GTS-t VSPEC
Most mods you do to the car will not increase the resale value much. Whatever you spend will be wasted.
Wasted but thoughly enjoyed!!:D
Keep mods to a minimum. Is youe exhaust from turbo back or cat. back? If from cat. back invest in a 3" front/dump pipe from turbo with a hi-flow cat. Also make sure you muffler is a straight through type, as these are less restictive (3" all the way through). In crease boost to about 12-13psi. I wouldn't worry about a pod, as it only sucks in hot engine air (without being partitioned with cold air induction from front bar ) But replace the factory filter with a hi-flow item, such as a K&N or HKS, etc.
GOOD LUCK and enjoy!
Alan
https://www.sau.com.au/forums/topic/14946-newbie-needs-help/#findComment-304031
