I just got my new fully forged bottom end running yesterday and the car sounds like it has a supercharger on it and you can hear this really high pitched whine comming from the engine.
The engine runs fine appart from running around 10 - 15deg higher then normal.
Anyone got anyideas why it would make the sound and why would it run hotter? the gauge in the dash reads normal readings its just the PFC that is saying it sitting on 101deg/c
If you have done a new timming belt it could be that, mine did the same and it turns out it was to tight and we just backed it of a little and the noise went away, and some belts are noiser than others.
Yep. Gates NEO
I haven't personally used a gates belt, but they have a bit of a rep for being quite noisy. I have heard a few cars with them, and yes they were noisy. It's quite possible though that it is just not being tensioned properly. were the tensioner and idler bearings replaced or checked?
get a long screw driver and carefully put it on the water pump housing, or the alternator or the powersteer pump, with your ear on the other end, if they all sound normal then your belt or tensioners may be noisy
cheers
Jeremy
gates timing belts are crap. Do not use them...
I installed one with the new idler/tensioner bearing's.
after about a week i had this really weird noise at idle coming from the front end.
after 6 months it was getting really annoying so i
did the screw driver trick, and the most noise was coming from the cas.
chucked a spare cas on and no change, so i removed the timing cover and instead of the blue gates belt i found a black gates belt. i was puzzled by this so i stripped the balancer, lower cover, etc off and found all the blue crap from the belt was now coating my new idler and tensioner pulley.
the coating that they put on the outside of there belts is useless.
removed both pulleys and hit them with the wire wheel on the cordless, and came up good as new.
replaced with a genuine nissan belt and havent heard a single noise since.
So the moral of the story is,
stick with genuine.
Cheers
i use a gates belt on my car, never once has been noisey. prob overtensioned as the others have said. p.s the blue does flake off my i doubt that was the noice, id say you overtensioned your belt also causing the belt to overstretch and strip the blue *gates* off.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
