recently had a full respray (engine out) and just dropped the engine back in but it wont start. Everything is hooked up properly and its turning over and getting fuel and spark but it just wont start. Has anyone had this problem before? Ive searched but come up with nothin.
Nick
https://www.sau.com.au/forums/topic/149504-car-wont-start/
Nick
try another battery 1st
then check all fuses etc,
https://www.sau.com.au/forums/topic/149504-car-wont-start/#findComment-2787719
spark was alright as nothin was taken out before or after engine was in or out. And the battery was alright to it goes flat from cranking over to much but its chared again now. Ive checked all the fuses as well.
All i could find was some guy had same problem which was an injector fuse (dunno where they are) And people have had a problem with the CAS but i dunno how to tell if its not working.
Nick
https://www.sau.com.au/forums/topic/149504-car-wont-start/#findComment-2788442
I just noticed then when tryin to crank the car over theres no oil pressure on my guage, after afew cranks the light goes away and then stop cranking for a few seconds and straight away the pressure light comes back on could this be a problem?
https://www.sau.com.au/forums/topic/149504-car-wont-start/#findComment-2789560
not a problem, wouldnt stop it from starting, get a mechanic friend to check if its sparking and pulsing the injectors, or are you mechanically minded?
one thing i have learnt is that even though a customer says it has spark is to check it any way, 9 times out of ten there wrong.
not saying your wrong but....
https://www.sau.com.au/forums/topic/149504-car-wont-start/#findComment-2790398
