hey all just got a new set of 17s for my 95 r33 gts25t, just wondering what ppl think about them.
http://s43.photobucket.com/albums/e354/85_gsr_cordz/r33/ pics are there. wheels are avanti force 17x8 with yokohama s1-z 235/45 tyres all round. anyone know how good these tyres are wet and dry? nad how much ppl paid for these tyres if they have them. grip is so much better than the 225/50 16 nexen n2000 that were on the car before.
Edited by matt_085
https://www.sau.com.au/forums/topic/149517-new-wheels-on-my-33/
Hey mate, thats heaps better than stock , will handle better too!
But i also have to say im not a fan of the wheels.
Each ot ther own man, they dont look ugle but if ur buying and choosing they arent something id go for.
Clean looking skyline by the way! :)
they actually not my first choice but the ones i wanted wouldnt fit the front as the were hitting the caliper, so they measured them up and found that there bigger than standard gts25t calipers, but that said i really like them dont look as good in pics though
Yeah the front calipers can be a bitch, the owner before my current r33 shaved a bit off the front calipers to fit the wheels on . i didnt like the idea of that but whats done is done.
In real life they would look heaps better i bet.
They are by no means ugly man they definently make the car look better!
normally "aussie" spec rims wont fit onto skylines due to hardly any of the locally produced cars having 4 pot fronts. fords, holdens always seem to have twin piston sliding - which makes for very easy caliper clearance.
that said... yokohama make very very good tyres... all my sets up to present have been yokis and i wouldnt touch anything but. (except for maybe semi slicks)
yeah the weird thing was they had fitted a set the wheels i originally wanted on a 94 r33 just before christmas , thats why they were sure they would fit. is the much clearence between the rim and caliper with the standard rim as there was only about 5mil clearance with the stock wheels. i just had a read up of these tyres and there speed rated to 300km/h and are sposed to be one of yokohamas best tyres
Edited by matt_085
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
