Well I had Redline put into my box.
Just drove the car in after a 5 min drive from work.
Jacked the car up on stands - shoved a pan underneath and out it drained - the oil complete with cool gold colour sparkles came out lukewarm.
Needed a handpump to push the oil UP into the gearbox. Too a little over 3 litres.
T.
tony i think they are talking about automatics man..... what u do is..... with the car at operating temp and still running.... put your foot on the brake and pull it into first then neutral then reverse a few times leaving it in gear for a few seconds each time then into park then check should be on the full HOT bit on the stick......u will have to look hard as old trannie fluid is hard to see...... and another tip if your oil smells like its burnt take it to an auto transmission place and get the trannie serviced/checked/change fluid........ hope that helps u out.....:uh-huh:
I think various makes and models are different, some are checked in or out of gear, hot or cold. But the way we did Falcons and Lasers etc when I worked at a Ford dealership is with the engine warm, in drive, with air con on. Not sure if that's "normal" or not. From memory the difference is not all that great between all the above variables.
Originally posted by WHITE R32
with the car at operating temp and still running.... put your foot on the brake and pull it into first then neutral then reverse a few times leaving it in gear for a few seconds each time then into park...................
hahaha.... isn't that a bit over the top?
Motor at running temp,
car in neutral.
Wipe stick
Put stick back in hole,
Read fluid level,
Repeat (to make sure that it was accurate)
Pffffffff men....
Have to make everything so complicated. :D
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
