  • Replies 88
  cheez said:
just want to know, with the longer under body neons how ppl have mounted them under the car? have you used the supplied brackets or custom made brackets? wats the go?
The go is dont put them on ..They look gay..
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2788743
man they look tacky and make your car look cheap...
go without
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2789117
hey guys got em as a gift from my mrs.
i have the ones inside at the drivers feet and passenger feet, and matching green light emitting from the boost gauge face.
cant tell her i dont want em, but ill put em on for her, and ill only turn em on when she wants me too (not when im driving) like those chocs. dont wanna hurt her feelings
just wanted to knw if others had mounted b4 to save me some time.
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2790110
Hey guys
Regardless of weather u lik them or not, hes asking if anyone has some install ideas not wheather u lik them or not.....
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2790151
zip tie em on. you don't wanna put any permanent holes in your car, esp if you might have to take em off if people start laughing at your car :P I'm fairly confident they won't get hot enough to melth the zip ties.
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2791678
  ali-turko said:
arnt neons just another thing u can get a canary for
I had a friend go to the cop shop to find out a while ago, and apparently they said they're fine, as long as they aren't blue or red.... >_<
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2792750
thanks for the advice guys.
ended up zip tieing em on, worked a treat.
put the driver and passenger side on wit em , but the front 1 i used the supplied clips that i screwed onto the bottom of the plastic engine cover.
at the moment trying to work out how to mount the rear 1, its a bit harder coz got exhaust to contend with, but will find a way around it.
thanks for the help.
and to all u baggers, girls obviously like neons. (thanks)
LOL
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2793194
Hi all my first post, I have neons, yes all my girlfriends love them, I got them because I saw Paris Hilton had them on an episode of the simple life.
Then again I am blonde and have my moments.
As for them being gay as well, suppose that captures me to some extent as I am also bi-sexual.
Honk me when you see me on the highway or down Chapel Street.
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2794693
  cheez said:
meh,
honk if u see me? damn woman what car do u drive? how do we recognise u :) (photo)
Be blind to miss me in a white 96 GTS-T coupe, been lowered with body kit and three inch exhaust. Normally riding with me are three girlfriends pumping out Hed Kandi on the stereo. Always seem to get pulled up by the cops outside Kentucky Friend Chicken but a bit of cleavage works wonders.
https://www.sau.com.au/forums/topic/149596-underbody-neons/#findComment-2797188
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
