yeh sounds the same for me, just white 95 gtst, gtr front bar with big greddy front munt, and 3.5" turbo back exhaust with 4.5" muff. with a standard cat i get 88db. lol
i get pulled up outside chasers, opposite kfc. everything rwc so they can jam it up their asses. no clevage needed. lol.
  • Replies 88
you know what to do....flash them your clevage cheez when you get to epa
I swear one day I'll buy a $100 POS take off the exhaust and tune it rich and do drive by outside the EPA for half an hour just to piss them all off
Edit: and omg Mel is teh hotness...............yes guys I'm just saying what you are all thinking...MUAHAHAHAHAH
you guys are the biggest sellouts ever... next thing you know your R33 GTSt's will be rocking prada and D&G interior trim.
meanwhile... i'm off to go ziptie my LED underbody lights on... coz apparently the chicks that do chap laps love it.
how bout some louis vuitton interior trimming then? :P
FUNKYMONKEY...!!!!!!
HOW DARE YOU..HOW DARE YOU..........................YOU FORGOT GUCCI...........MY FAVOURITE LABEL........LOL
Seriously guys just do what you feel comfortable with, don't try to impress the girls if its not you. We will suss you out cos you wont look right and won't feel comfortable with all the attention. I wouldn't expect a tattooed truckie to be running neons on his rig...
Wear it only if the shoe fits ya.
Mel
there was a lambo with either LV or gucci interior.......a bit of overkill..............
I wouldn't mind some nice white neon lights in the boot or my car, problem is, where do I mount it?
the OEM light is truely, truely pathetic.
i like neons :huh: i got LEDs under the car that change colour :) blue parker lights LED washer nozzles, interior neons, boot neons and even a blue neon bulb for the interior light, also just got sum for the grill and front bar, geez i luv neons :)
FOTOZ please!!!
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
    • RB20/25 covers don’t have threaded fasteners stock like RB26 covers. They are blind rivets so I will need to drill out and tap threads. I bought some M4x6mm button heads and will report back once done if I chose correctly length wise.    have also got some loctite
