Hi,
I was driving back from work the other day and my car was running fine. I was giving a a good burst from time to time then started to notice that the power was progressivly decreasing. By the time I got home I could not boost it over 5psi and at the point it runs realy rich...
I know its rich due to the state of the plugs when I pulled them out to do a compression test, which seemed fine as well (all within 10%).
Things I have done to fix it are:
1) re-fitted all intake piping after the Afm and before the throttle body, there were no obvious leaks.
2) replaced the Z32 AFM with a mates and it made no difference.
I was thinking it could be:
1) crank angle sensor?
2) plenum gasket?
3) maybe a pin hole in the cooler, I have checked and cant see anything?
Any suggestions would be great, I am thinking air leak but its very hard to determine where it might be???
https://www.sau.com.au/forums/topic/149616-possible-air-leak-please-help/
  • 3 weeks later...
Did you end up sorting this out? I had a very similar problem, and it's turned out to be a plenum gasket for me.
I could actually feel the air rushing out through the giant hole.. I could still get a heap of boost into it though, but it was making a rushing air sound out the side of the plenum when on boost.
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
