  • Replies 41
im just trying to suss out where to run my intercooler in my MR30 so if anyone has any pics of there setup on either a HR30 or MR30 post them up it would be a big help
This give you the right ideas?
Cheers, D
Pretty sums it all up well.
Im running mine thru where the radiator bottle usually sits. Drilled some 3" holes. Works well
thanks guys thats a huge help got any pics of your setup stagefumer11
It's not rocket science!
Just remove the overflow bottle and run both in & out pipes through the radiator support panel beside the radiator.
Cheers, D
Cheers, D
i know it will go through the radiator support pannel fine but getting it around the Receiver Drier is my main concern cos i want to keep the Aircon
Me too!
I guess the front of your MR and my HR are similar?
I will be sacrificing the headlight washer pump, but I think a bit of custom pipe work for the air con connection to the filter will be my only concern.
There is 60 & 70mm clearance over and in front of the filter for pipes to go.
The configuration and size of the intercooler is the biggest consideration. It is my belief that core sizes in the vicinity of 600 x 300 x 100 are a WOFTAM for our application. These things flow enough air for upwards to 1000HP and when we are talking in less than half, I can't see the point.
A long time back now rsx84 put me onto a DR30 HKS Drag Intercooler at Option 1 Garages in Brisbane. Everyone on this forum, including himself ignored it and dismissed it as it wasn't big enough for their application. What they didn't consider was the maker (HKS) and the purpose it was designed and built. It's only 400 x 280 x 65 core, but it flows a huge amount of air and enough to easily support 5 or 600HP. Some imaginative piping has to be made so it works with the L series, but it still is probably better than the monsters they fit to their own vehicles.
Some on these forums believe stock R32 & R33 intercoolers will flow 350HP and thats more than enough for a turbo L24E and are quite compact and have the piping going the right way.
Have you ever considered this configuration???
It is by far big enough for my L28et application & I'm looking at 300+ HP at the wheels on a good day at under a bar of boost.
Cheers, D
Good reply.
Other intercoolers you should look at is top mount units off celicas and Gti-r's They flow enough to support a l24et (there is a factory nissan l24et beleive it or not! ) Or a l20et. I was using a top mounted GT4 celica one. Made a massive diffrence over none at all.
Still got it up for grabs also :P
Good reply.
so you have a top mount setup for a l24 with piping aswell
I had a top mount cooler running in the front. Been removed awhile ago. No piping anymore as that was used for the new upgraded one. Which has now been sold as a package.
Got the cooler still. Both outlets are on the same side, Core is about 300x300x70mm or so. PRetty good :)
Got the cooler still. Both outlets are on the same side, Core is about 300x300x70mm or so. PRetty good :dry:
how much you want for it
make me a offer, it has a little bit of scuffed fins, but ok condition. Dunno what the shipping would be on it
its ok ive got one sorted this is what im getting
Im not getting it till the Australia day weekend so when i get it what i will do is take some photos of my progress and do a step buy step procedure for installing it and i will also do the same with the L24E turbo conversion
Edited by the big JC
looks good, the core doesnt look like a good flowing one tho
o well shit happens it will be good enough 2 get me started
all i have left on the list of things is
.oil pump
.vaccum controll thingy
.boost gauge
.boost tee
.bov
.R33 GTS-T turbo and dump
and then it will finally be time to start YAY
.oil pump
.boost gauge
.boost tee
.bov
The oil pump is a must, you have to get a turbo L series oil pump.
The L20ET pump will do, but you can get bigger, just depends on how much money you want to spend.
I have a type 1 BOV if it's of any use to you, I bought it for a similar conversion but never used it. I also have a new VDO Boost gauge and a manual boost controller (same as advertised on these forums) a bleed off type ball valve controller.
PM me if your interested.
Cheers, D
i had a 600x 300x 75mm cooler fitted to the HR for a while till i removed it to use in the r31, mounted with the inlet and outlet pipes below the front bar surports, piping was long as it ran back behind the cooler and both came up through where the air box was....
i will be putting a similar sized core back in but mounted differently so i can reduce the length of piping...
core in the same spot but mounted upside down (inlet & outlet at the top) 90deg bends straight off the inlet & outlets, holes cut in body just below the lights then piping straight to the turbo, maybe a front facing plenium (i have an rb engine) to save an extra 1-2 foot of piping..
a mate has a similar set up in his r31 and theres at least 3-4 foot of piping saved compared to my old set up....
Edited by rsx84
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
