Myth or Fact?
Sediment collection from running fuel tank too low?
I think I've read about this subject before but here we go again. I came to the conclusion that it was a myth, as for Fuel is drawn from the bottom of the tank so having a low tank wouldn't make any difference to a full tank, BUT, I've just come across a quote from the Nissan website & now it's got me unsure again!
http://www.nissan.com.au/owningNissan/vehi...enance.asp#fuel
Also, avoid running the tank too close to 'Empty'. Petrol impurities and sediments collect at the bottom of your tank and can cause problems if drawn into the fuel line.
Can someone please clear this up & technically explain why it's myth or fact? If it wasn't for me reading that Nissan page I would have still thought it was a Myth.
https://www.sau.com.au/forums/topic/149667-myth-or-fact/
my theory is that when the tank is full, the sediment, or crud as i call it, is more diluted around the tank. but when the tank is low, the crud is more concentrated so its more likely to get drawn inot the line.
remember......i said 'theory' :)
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2790339
Yep thats what it says in the manual. Also mechanics will tell you the same.
I'm looking for a little more than just “Nissan & Mechanics say so”, I like to know how things work so if somebody can technically explain why it's a fact that'd be great, thanks :)
Edited by geno8r
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2790343
yeah bingo not good for your fuel pump especially i've had a few friends who run their tanks to the very last drop constantly and as such have had fuel pumps die early......
i do on occasion run it until the fuel light is on unintentionally but most of the time ensure the tank is as full as possible.......
think about it --- say you're drinking a drink using a straw, do you really like scrambling for the last drops from the bottom of the glass, or do you prefer drinking from a full glass? the fuel pump would feel the same about trying to feed your engine its fuel
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2790353
Makes sense, but not really a direct answer to my question, more a related answer *but thanks for the knowledge anyway :ninja:*.
Getting back to the actual sediment issue.
Sure, but over time I guess it's all going to get sucked through the injectors anyway seeing fuel is drawn from the bottom right?
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2790392
Ok, your fuel pump runs hotter (less lubrication cos not much fuel there). Your fuel injectors will get clogged up with all the petrol tank gunk. Thats the two main worries.
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2790468
In both my skylines that have been over 10 years old, the tank has been crystal clear whenever I've gone to change the fuel pump.
I think it's a bit of a myth in most cases, but that said, there ere are probably a few out there that have had dodgy fuel put into them in some Japanese country area or something, and hence crap gets in there. So the only real way is open up your tank, shove a torch in and have a look for yourself.
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2790750
nissan might recommend not running a tank empty due to overheating in fuel pumps, less fuel pumps fail early less get replaced on warranty, i doubt its sedimentation and more the overheating fuel pump failing
my couple of cents eh
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2791412
So why do you have a fuel filter in your engine bay? To sit there and look shiny... no, it filters the fuel before it gets anywhere near your injectors.
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2791690
Do you realise that you can clog up your petrol filter way before the 15000 KMs intervals its meant to changed?
Obviously, its a filter so its gonna clog up, so change it before the 15000KMs interval if you think its gonna clog up sooner. Its still a filter that sits between your tank and your injectors...
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2792425
Yeah but with that approach your car's not gonna last very long. If you wonna run your petrol tank dry and change fuel pumps and fuel filters every 5 000 Kms then go for it :wave:
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2792443
Just dont use a lighter =)
https://www.sau.com.au/forums/topic/149667-myth-or-fact/#findComment-2792607
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
