  • Replies 161
Originally posted by INASNT
U r right about the habibs tho cereal, all those vl turbo drivin wankers have upgraded to r33's!! its suxs
I had a VL Turbo.. and now an R33.. and im not a habib wanker..
Your so very quick to throw generalizations INASNT :P
teh GTiR is an awesome little machine.. and I beleive will munch many a GTST.. hell, i rekon they'll give a fair whack of GTRS some whoopass as well.
Definatley a little car id love to own...
Bren, you're right, you're not a habib. But you are from Melton so it's kinda like the same, ain't it ;)
How's the skyline going? Done any more to it since I last saw it at the Lorne cruise?
heh.. :P I knew that.. i just like stirring the pot..
:shake:
there are so many r33's now near where i live i see about 5 a day, and most of the drivers look like they used to or should be drivin vl's with inteceptors dumped on its arse with a turbo badge they pinched off sum1's car at the local shopping centre, if u get my dfift ;);)
Originally posted by wrxkilla
Hey rev210,
I'll race you anytime. Give us a break mate.
No need to call our car a peice of poo.
Whats wrong, cant you afford to buy the real deal Mr Skyline Taxi??? Geez, your one of them, I drive a GTST, my car is better than everything on the road. MATE - ITS NOT A GTR
Go home.
Stock GTiR running Pod Exhaust 14psi.
I'll blow you out of the water. And I'll leave it at that.
Chill mate.
'Peice of poo' are your words not mine. Sure I have some opinions about the car that might sound a little depreciating but, I didn't knock the performance at any time. I might be a little envious that I can't fit into one because I like the idea of having a car that looks 'family' (ie: not mean or sexy) and can kick ass. Horses for courses mate. You don't like line's cause they look like taxi's I don't like GTiR's cause I can't fit in them (just cause they look like a *#%* box doesn't put me off).
Do you think your car is better than anything else on the road? sure you do! you would have sold it otherwise. Better than 'almost' everything then? I'm sure you believe that too, once again you would have sold it otherwise. What about better than everything else on the road? I can't say I do, there are a number of cars I would much rather be driving than the R33, I just can't afford them or they don't fit my application well enough.
BTW, can afford to buy a GTR, just didn't because the gtst is the car I use for work (better fuel ecconomy).
I have only done a 13.4, what have you got to worry about? thats pretty darn slow. From the sounds of things GTiR's will kick my ass on a good day, then again talk is cheap and racing is fun.:P
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
