i got some vs work wheels for sale 1600 o.n.o
i would like 1600 for them but reasonable offers considered for quick sale
the stud pattern is 5x114.3, 18x8 offset is +38 would require spaces to fit a skyline gts-t fronts only also might need guard to be rolled 255 rears
plaese note: there is no gutter rash on any wheels
in excellent condition
tyres are about 80% + in sydney
2 x falken 225/35/zr18 front
2 x falken 255/35/zr18 rear these tyres cost 1200 new, no wind noise like nakang tyres make
they've been balanced not fitted to car yet
they are 2 peice rims might be 3 not sure
would also swap for wheels with lots of dish, i want very japanes 2,3 peice deep dishes like 10 inch wide and 12 inch back plus cash you way
thanks, josh
also note: the outer dish is from another car 5x120 it says but the centre is for merceds, rx-7,skyline s15 silvia 200sx etc may requires spacers for skyline gts-t front only see pics
Edited by ijoshi
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
