i was thinking v8 myself it would be a machine alright, and i would really love to put some sort of rb in it, i live up in Nrth Qld Townsville and none of my mates are mechanics (well they think they are mechanics in their own minds lol) yeah its just gonna be a lot of greaf for me cause ill have to get someone else to do the work and thanks for that link makes more interested to do it
cheers
darryn
  • Replies 61
For easier fitment i'd go a smaller engine than any RB.
An SR20DET would be nice and small with decent power using bolt ons, and you can get monster power out of a built one with a decent turbo if you're serious about upgrades.
Or a 20B triple rotor turbo, plenty of poke for a car that probably weighs 1100-1200kgs, and they can handle upgrades fairly well.
Went for a spin a 65 Cortina (weighs 1050kg) with an S14 SR20DET the other day, 12psi, tune, FMIC. Damn is is that fast! Its just so lively. It's capable of a high 13 flat with only 155rwkw, more boost = easy high 12s
Yeah but my problem is where could i find a rebuilt one??? and would the custom engine and piping and stuff like that cost me an arm and a leg u recon???
cheers
darryn
Finding a rebuilt one would be difficult, but how much power are you chasing?
If it were me, i'd buy an S14 Silva front cut, using the engine, gearbox, looms, brakes etc, possibly suspension if coilovers could be made to fit. (guestimating about 5K for a front cut, havent really looked so i dont know)
If you put cams, injectors, fuel pump, boost cont, ecu and find a decent turbo/manifold, GT-RS or something decent, i reckon you could guarantee 11 second passes, and you would have trouble keeping traction in the dry in third gear.
It would make one hell of a weapon
See thats the favourite thing about my car because i got it handed down to me with mags and paint from my brother so its mine now, VSPEC-33 do u really think it could do a 13 sec pass if i put about $15k into it including labour???? see thats the biggest one i will just be dissapointed if it doesnt go hard and i put alot of money into it. i will be blown out of my mind if i could rock up to a set of lights and people laugh at me and then just leave a trail of smoke in their face :D
Provided you kept the car lightweight, cant add a huge stereo or anything because because weight is your enemy. I recon you could crack a 13 sec pass with a standard turbo, boost @ 15psi and a good tune.
If you have any mates that could help you put everything in the car you can save yourself some dollars. Alot of the costs will be fabrication and engineer certificate, so if you find a workshop thats wants to help to you out ,and not just take your money, you should be able to meet budget.
Years ago i thought about doing the same thing with an E30 BMW, the SR to me was one of the better cost/perfomance/weight ratio available. Plenty of aftermarket parts avail too.
thanks for that site vb, and yes it will be very hard finding a shop to help me out with this project and wanting to actually help not make a sh!t load of cash out of it, the only thing im really worried about is the budget on this machine. But as im looking around ill just have to save really hard
darryn
Yeah i know, thats the thing i really love skylines but their is sooo many of them around and i just want to be different for once and anyone has to admit it would be a kick ass sleeper that know would ever expect to get eaten up by it!!
my opinion 2jz
thought about 1uzfe? strongest production engine in the world= potential potential potential, totally alloy engine and wouldnt ruin the dynamics of the car
vq35det? now that would f**king hammer
1gzfe? (think thats the engine code) toyotas 6.0 v12 :drool: out of the century's if u could get a hold of one that is.
is a 4 cyl turbo really worth it? weight wise
i reckon look for a alloy block 6 or 8 and then u can have the best of both worlds
1gzfe - 5.0, not 6, also hideously expensive and spares are non-existent
1uz - nice but easier to get power out of a 2jz, especially with limited budget
13B - reliability issues. rotary+budget=myth
2jz should be able to do with that budget, but by far the best option, providing your gonna go auto, 6 speed, you got no chance with that budget
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
