  • Replies 56
Posted Images
These are sooooooooooooo coool age. Cand you do a write up for these puppies in a nutshell? Or is it a little too complex for us photoshop novices??
that's right AGE... its about time you stepped out of the VIC section and did some tutes for the graphic design section.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794545
Ummmm, it's alot easier to do them tha it is to do a DIY on how to do them. ;)
You need some big pics of the actual pixar cars themselves, and cut and paste the best fitting eyes and mouth, then free transform/distort(ctrl T) them to fit. Then it's just a case of matching the color of the donor car with the cut and pasted parts.... thats the hard part, and black cars are the hardest, surprisingly yellow was very easy :)
I use lumination/replace color/brightness/contrast and matching color tools on photoshop. Also alot of history/eraser and eye dropper/paint brush tools as well. It a bit of work to match the color, but playing around with different tools, you'll sort it out. Best thing to do is start with a white or light colored car and play around with different tools. Ctrl Z is your friend :P
Here's some more.
https://www.sau.com.au/forums/topic/149791-carz/#findComment-2794585
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
