they are not bad. no real life experience with them, but have heard a bit about them. Done a lot of research myself, and decided to go the next level up in the falken range, the Azenis ST115's.
The tread pattern looks awsome on the GRB451's, and i havent heard anything bad about them.
The falken Ziex i have heard bad things about.
https://www.sau.com.au/forums/topic/14980-falken-grb/#findComment-304212
I have Falken FK-04GRB's on mine and they're fine.
They Grip well in the wet and dry. I don't have any complaints.
I've done a few 4k launches (in back streets where there is no danger to other motorists) with them and they grip well and the car rockets off :(
https://www.sau.com.au/forums/topic/14980-falken-grb/#findComment-304268
Yeah, I reckon they are good. Had FK451s on the rear before these, they have much better grip for cornering, but the tune2's have better straight line grip.
I'd give themn about a 7.5/10 for performance and a 9/10 for value
https://www.sau.com.au/forums/topic/14980-falken-grb/#findComment-305123
    • RBF660 doesn't meet DOT5.1 as it is too thick. DOT5.1 has a very low viscosity requirement compared to DOT3 or 4. (Dot5.1 must be half as "thick" as DOT4)   It would also be a big indicator for anyone using that fluid in extremely cold weather to possibly look to swap for something in the DOT5.1 range.
    • Here is as close as we got to a direct comparison(3 vs 4inch exhaust), a tickle more boost, which I am sure was in part due to the exhaust.  Made 790 on more boost.
    • Next minute, carbon fibre boot 😂
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
