Well so i was sitting on the net, going over all the CAI designs, ones you can buy and so forth. I remebered that a member of the forum had some templates. SO got those and went to work.
My dad and I started in the morning on boxing day, figured we would take it easy, well 4 hours later, and a six pack of beer, and HAY PRESTO, here is the finished result.
The box case is made out of a product called ALUCOBOND, it's a 1mm ally, with 3mm PVC, and 1 mm ally again. You can buy a thicker ones if required. The inside is lined wiht a THERMOFOAM, it's a 15mm thinck high density foam with silver foil, excellent R values, to miniminse heat transfer. I noticed a 6deg C after introducing the foam.
The air is introduced through a 2'5" pipe from the front of the bar and blows straigh into the box.
SO far the results are great, the car is a lot more constant, if you stand in trafic, the heat lag is gone. The air is nice and cool, and the car is a lot more responsive. Fuel ecconomy is up, and the pod noise is reduced to a more acceptable level.
Only down side, on a cold morning, the dam thing hits R&R so dam quick, as the air is so dense, and the box together with the FMIC, really increase the air flow, hence R&R.
I have the templates available, if people are interested, but i modified mine as i went allong, i found that each car is different. I have done this to my friends R33 4door, with an APEXI filter, and we had to extend the main box body and make a different cover top.
I did mine by making the side first and then making up a pattern to fit for the top cover. The side of the box is held in place by two brackets riveted to the side of the box, and bolted to the car using the stock airbox mounting holes. The top is slid inot place under the front panel, and then bolted through the top, into some brass L-brackets. I then finished the alluminium by brushing it with fine still wool. I did have it polished, but it was VERY hard to keep semi clean. Total cost, ALUCABOND, free i got offcuts, Thermofoam $36 per meter, and all the other bits and peices i already had, so that is DAM Cheep.
Tell us what you think.
Edited by WogsRus
https://www.sau.com.au/forums/topic/149816-made-a-new-cai-box-what-you-think/
  • Replies 40
Posted Images
looks shmick.
I've been meaning to make one, but just waiting to get my hands on a snorkel before i size it all up.
WogsRus, you should consider selling them on here. I'm sure there'd be alot of interest, especially if your prices arent over-inflated like alot of these boxes are.
Like i said most of the materials for me were of cuts, and there is plenty more to get. The only problem is that each box is really individual, if you want to do it corecctly. I made sure that there was no leaks or anything, the box fitted well. Depending on each car's setup, the pod hole may be in a different spot and so forth.
I am happy to farward on the design templates as were give to me, i can't take credit for those. I simply improved the design a little, and made it more functional.
BUT i suppose if you had to get materials yourself it would range from $50 if you get some scraps and stuff or about $100 if you did it all brand new, but for $100 worth of materials you can get 5 boxes cut.
Edited by WogsRus
Here is teh templates and some instructions as i recived them from the original maker. I do not take credit for these.
MY design is slightly different, in that i made brackets up to hold the side part of the box, and some brackets to screw the top down into.
Like i said i made mine as i went along, but the template is a good base to start with.
If you need any more info, PM me and i'll try and help, and provide some more pics.
cai_zip.zip
Pics.zip
CAI_Template_Inst.txt
Hey all i am in the process of making one of these for my s1 4 door. The only thing where something can differ is dependant on what type or airpod you use. I have an apexi and wog has a hks one. the hks filter sits off a pipe that you can go around where as the apexi bolts straight to the aiflow meter, so its a bit more tricky to get attached
I used the old hole form the stock IC, you can see it in one of the pics. There is a 2.5" pvc pipe that runs form there to the front bar, and picks up cold air form the front of the car.
You could easily use a stock snorkel and plum that inot the side of the box at the top, but i didn't have one.
If you are looking at the pics of the white car, the orignal template pics, he made a hole in the front fender to duct in air. I didn't do this as i already had a hole.
BEST thing if you have a stock snorkel, use that to supply the cold air into the box.
EDIT: I can't spell at ALLLLLL
Edited by WogsRus
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
