What Kws At The Wheels Is Ur Skyline Making...
Adz2332
 Share
Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 152
Posted Images
"You cant just jump in the ring with Ali caus u think ur box. Hey he knows i can box. So check it, if i lose the winner takes my car clean and clear. But if i win, i take cash, and i take the respect."
R32 GTST, usual mods, stock turbo 170RWKW @ 14 psi
Edited by R32Abuser
".....so check it, if i lose the winner takes my car clean and clear. But if i win, i take cash, and i take the respect."
Stuff the respect I'm here for the chicks!
R33 GTS-T (manual-auto) 203rwkw @ 13.5psi from Boostworx.
that would be SLO-031
my best was 177 my worst was 154 i dont know why it lost power from one run to another but i know it hasnt stayed lost just cant afford to go on a dyno every other week
i remember i was in my silo when this bloke pulled up next to me, i was like ohh ok, then BANG 100 meter
wheelspin :O
i saw his plates "slo-031" i was like :dry::O:O:O:O:O:O
My lil' 66 skyline is doing 140 at the treads, but with the new bits ( turbo, zorst and a couple of other things) I am hoping for 180kw at the treads ( I want to be australia's most powerful 6 cyl Prince Skyline GT-B) not that I am not already... hehe :dry:
Edited by 66 skyline gt
Hey ,
my GTR was tuned at 262 rwkw at a bar,
now with more boost and electronic controller prob pushing 280 +
but its a GTR so all the power transfers to the ground and the magnesium wheels being light it makes it more responsive
mike
^^^ GT42R infact
last made 378kw on street tune
apparently having a 2spd powerglide put behind it
lol my bad.. GT42r... Lunatic. :)
Yep a powerglide is going in behind it as the r33 auto built up had issues holding the power. Not surprisingly really as 373rwkw is a rather large amount of power. :)
geebus! some of yous have some serious power! i'm shitting myself in my little 80kw mx6 turbo around corners (that is with a blown head and running at 2psi hahahaa) and some of yous are hitting 300kw mark! damnnnnnnn
Back that up with having issues trying to get it into reverse when required .... :laugh:
Looked good on the Smasa Cruise. I think that's how you spell it :kiss:
153.1kw @ 11psi via Boostworx
Stock Turbo, 3 inch exhaust, crappy cooler, ..errr....fuel pump & Air Filter
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
