Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 152
Posted Images
corrans is manual sohc Rb30 made 710hp on allans engineering dyno on pump fuel.
alexs is Rb30/25 dohc, 900hp roller, glide etc, jakes ... 1000hp roller ,sohc Rb30,glide. Then there that green r31 with the Rb30/25 with the turbonetics T76, apparently thats nearly ready... few up and comers.
Thanks for reminding me about the liberty if we are on the same wavelength(pt rd)
I have been trying to forget about that night:)
We have matching wavelengths then :) Was a good night never the less. Even though you seemed to leave in a hurry for some odd reason :) Did Corran make 710hp? I thought he was just making over 400kw at the wheels? What's Jake have.... the silver VL that's been off the road for a while? (tubbed Silver VL?). The Green R31 I think from Memory is Chris', friend of Alex (played footy with them both... and Alex is my uncle... whose younger than me ;) ) I noticed you didn't put your car up there :(
Incase you haven't noticed I'm the white R32 that follows Alex everywhere ;) ... well, when i can that is lol.
We have matching wavelengths then :woot: Was a good night never the less. Even though you seemed to leave in a hurry for some odd reason :) Did Corran make 710hp? I thought he was just making over 400kw at the wheels? What's Jake have.... the silver VL that's been off the road for a while? (tubbed Silver VL?). The Green R31 I think from Memory is Chris', friend of Alex (played footy with them both... and Alex is my uncle... whose younger than me :P ) I noticed you didn't put your car up there :thumbsup:
Incase you haven't noticed I'm the white R32 that follows Alex everywhere :) ... well, when i can that is lol.
Corran made 710hp, it hasn't seen a chassis dyno yet, yep i remember seeing your car all the time,
remember we had some fun when i was in my turbo old ke10 corolla that looked full grandma styles?
Jake has a maroon mini tubbed vl...don't know what happened to that silver tubbed
vl, last i heard it was ready to go again...that was about 2 yrs ago, seems to be one of hexed cars that
keeps having probs
cheers
darren
I just put out 242kW at the rears on Monday at Boostworx. That PowerFC and boost controller were the best money I've spent on the car yet :woot:
I'm poor now though. :)
nice so you went from standard boost and map 177rwkw to a tunned PFC and bit more boost probably double the boost to gain 65rwkw
IMHO a well tuned bolt on GTR is probably one of the best all round street cars you could be driving though Jim.
Atm i think my car isnt even on the limits you have to select.
Stock RB20DET in my 4 whore.
Pod and a 3" cat back system from ET leaves me with nothing to gain except the wank factor of a louder car. YAY
I need more money
Yeah not double the boost though, just from 11 to 14 psi, I also gained about 80Nm of torque.
Yeah, I'm more than happy with it! I don't mind being poor, it goes hand in hand with a GT-R! :)
Edited by slimjim
  • 3 weeks later...
AS of 3 weeks ago
471rwkw at 6700rpm on 26psi/780nm of torque
PUMP FUEL, through a loose converter and powerglide
boostworx dyno
RB30 single cam powah!!:) still has casties and stock rods, ha,ha.
cheers
darren
Yeh nice work Darren....... I take it that was WITH a non broken engine mount :happy: From memory that was a stinker of a day too, until a certain A/C got installed :wub:
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
